It is currently Fri May 08, 2026 2:22 pm
PostPosted: Fri Oct 21, 2005 8:38 pm
I'm changing the trans fluid tomorrow. I misplaced my shop manual and can't remember how many pints my 904 takes, including the torque converter. I want to say 17 pints, but need to know for sure! Also, does anybody have a brand preference for the trans fluid? I use Valvoline Dexton III last time (4 or more years ago). The fluid now is not the red it should be....its almost like an orange! :shock:
 Post subject: Good Memory.........
PostPosted: Fri Oct 21, 2005 8:42 pm
My 65 factory manual says...................
Transmission and Torque Converter 17 pints.
As for brand, no idea as I haven't done it on mine yet...
Or how about fluid to avoid......... :twisted:
PostPosted: Fri Oct 21, 2005 8:44 pm
I alwez go ahead and get a case, just to be on the safe side! :lol: 17 or 18 pints sounds about rite.
I get the cheapest stuff (Coastal, Kmart, whatever), just cause that's how I am, but I like Valvoline oil, so your choice sounds good to me. The dexron is usually a bit more "orangey-red", type F is typically a darker blood red.
D/W
If it ain't broke, fix it!
PostPosted: Fri Oct 21, 2005 9:05 pm
Any Dexron fluid on the market today is vastly better than the stuff available when our cars were new.
That said, Chrysler's Mopar ATF+4 is so vastly superior to any Dexron that I use it in all my Torqueflites, even the oldies.
PostPosted: Fri Oct 21, 2005 9:15 pm
Funny you mention cheap Dennis, I was thinking about using Napa brand since their motor oil is made by Valvoline (so I've heard, plus, a napa and Valvoline bottle both have the same company name on the back). Dan, is the Mopar ATF+4 available anywhere other than the dealer? Is it like type F in its friction qualitys?
PostPosted: Fri Oct 21, 2005 9:37 pm
...tis true. Ashland Oil Company. NAPA and Valvoline are interchangeable. Some other part store brands are Valvoline in disguise as well.
D/W
PostPosted: Fri Oct 21, 2005 10:38 pm
Dealer-only until, ummm...last month, when licensing was started. Don't know if anyone's put an ATF+4 on the aftermarket yet. I pay the dealer price because (a) it's worth it and (b) I don't pay retail—nobody has to who doesn't want to.
Er...no.
Type F is a thoroughly outdated, thoroughly inferior old fluid.
PostPosted: Fri Oct 21, 2005 10:40 pm
That's why I use it in all my performance oriented stuff! :P :D
D/W
