It is currently Tue Nov 17, 2026 7:36 pm
PostPosted: Mon Oct 24, 2005 4:34 am
How do you tighten a Harmonic Balancer with the pan on? It requires 135 ft lbs of torque and I was wondering how you keep the motor from turning while you tighten the HB.
Thanks,
bwhitejr
 Post subject: Hammer It
PostPosted: Mon Oct 24, 2005 8:03 am
i usually just hit with my 1/2" impact. i have gotten a feel for what is good enough. if you don't have an impact. pull the starter and stick a big screwdriver or a pry bar on the ring gear to keep it from spinning. good luck.
zedpapa
1970 dodge dart w/225 /6 bored .040" over, holley 390cfm w/vac. sec., compcams 252s, clifford shorty headers w/2.5" exhaust w/flowmaster, f-body 11" front discs, aluminum A-833OD, 8 1/4 w/3.21 SG
soon to have 5 gears!!!
PostPosted: Mon Oct 24, 2005 8:10 am
I have been running mine for a few years with just the "press Fit"
I press it on with a bolt and washers that I stole from a 318. - The Impact wrench works real well for me..
PostPosted: Mon Oct 24, 2005 8:59 am
Mine doesn't have a bolt. Drove it on with a block of wood and 2 lb sledge hammer. :shock:
Jerry
PostPosted: Mon Oct 24, 2005 9:43 am
Jerry - I did the same thing too while my engine was on the stand. I was told by some friendly folks here that thats not a good idea unless the engine is standing on the other end of the crank as it could cause thrust bearing damage.
PostPosted: Thu Oct 27, 2005 7:32 am
When installing a harmonic balancer. I have heard that you are supposed to put RTV on it so it will seal properly. How does that work? What is the proper way to install the HB?
bwhitejr
PostPosted: Thu Oct 27, 2005 8:48 am
bwhitejr
For heaven's sake, DON'T put RTV anywhere on it. Coat the snout of the crankshaft LIGHTLY with motor oil, then torque it down with an impact wrench until its fully seated.
PostPosted: Mon Oct 31, 2005 12:34 pm
Pierre, I've heard that recently, too. Unfortunately, it's too late to worry about it now. The engine starts right up and runs fine, for now. Of course, we just got the car back from the paint shop and haven't put everything back together, so it can be put on the road for a test run.
bwhitejr, the only thing I put RTV sealant on was a harmonic balancer hub repair micro-sleeve. Sounds complicated, but it's not. If you check the outer surface of the hub that slips through the front oil seal (located in the timing chain cover), you may find a shallow groove worn by years of contact with the seal. Doesn't seem right, rubber wearing out the metal, but it happens. Your local parts supplier can probably get you a micro-sleeve that simply slips over the hub to provide a brand new surface for the front seal to press against. The instructions for the sleeve say to use RTV sealant when installing it on the hub. My guess is it's for lubrication and also to make sure no oil seeps by between them. MAKE SURE you don't crush the VERY thin micro-sleeve. Go slowly, and make sure you put it on straight and evenly.
Jerry
Users browsing this forum: Google [Bot] and 7 guests
