It is currently Tue May 19, 2026 10:46 pm
PostPosted: Mon Oct 24, 2005 6:46 pm
i have a 72 valiant that i just got a pst front sway bar. i got alot more front end work before this is goin in. Anyone else done this on a not factory equipted bar? pics anyone? i just need help on where my brackets to the frame need to go
PostPosted: Tue Oct 25, 2005 9:45 pm
hEY man
If you register and do a search, you'll find plenty of good posts on front and rear swaybar installation, original, firmfeel, etc etc etc.
Plus if you register we all can get to know you a little and call you by name (or names, :lol:) And follow up on you and your car's history.
Take care.
Juan
Juan Ignacio Caino
PostPosted: Thu Oct 27, 2005 2:33 pm
dood, i cant register for some reason. everytime i do, it says that email already has a name to it, and im not gonna get a new email so i can do this. ive had waaaaaaaay to many probs wit dis site, which blows. ive already tried to contact board leaders wit no luck. WEAK. i also wanna ask if i should remove my ballast resistor after my petronix swap, BUT i cant start a new thread for some reason, oy vey
PostPosted: Fri Oct 28, 2005 6:43 am
I can answer the last one for sure: You should leave the ballast resistor in.
For the first question, try to position the brackets as far apart as possible, and drill holes accordingly. I don't have a PST bar, but I have put an Addco bar on my '66, which originally had no sway bars.
"Mad Scientist" Matt Cramer
'66 Dart - turbocharged 225
PostPosted: Fri Oct 28, 2005 7:45 pm
well the kit says to bolt it through the holes on the k-frame, theres two on each side, and the outer one dosnt fit, and yes the main bracket is only attacked to the frame by one bolt. the piccture shows to just bolt the plate and the bracket together on the other end. im thinkkin of just makin my own hols, but the only place to do so makes it an extreme scrape hazard.
PostPosted: Sat Oct 29, 2005 11:45 am
i had a 1 1/8" PST bar on my '70 and i'm thinking addco made it and PST just drop ships all their stuff, which explains the higher cost. the mounts that come with those bars suck. mine used to scrape whever i hit a dip in the road or a speedbump (although my car was lowered about an inch.) the holes in the k-frame may need to be drilled out since there may be some welding spatter built up making the holes irregular. i think i saw pics on this site or over at /6.com showing a more "custom" mount for one of those bars. looked like it tucked up quite nicely.
-james
PostPosted: Thu Dec 08, 2005 2:12 pm
The pic that James mentions might be here:
http://slantsix.org/forum/viewtopic.php ... bar+mounts
Steve
