It is currently Sat Nov 21, 2026 6:23 pm
Post new topic  Reply to topic  [ 69 posts ]  Go to page 1 2 3 4 5 Next
PostPosted: Mon Nov 07, 2005 7:46 pm
See page two for the troubleshooting fun.
Ive got one on my '64 Polara engine, has a funny logo on the top plate, I think it says DPCO? What kind of pump is this and where can I get a rebuild kit for it? Id hate to throw it out in favor of a sealed unit. Also, what pressure should it put out? 5 lbs?
Last edited by steponmebbbboom on Sat Nov 12, 2005 3:15 pm, edited 2 times in total.
PostPosted: Mon Nov 07, 2005 7:51 pm
mebee DPCD kinda in a square? If so, stands for "Dodge, Plymouth, Chrysler, DeSoto"
D/W
If it ain't broke, fix it!
PostPosted: Mon Nov 07, 2005 8:07 pm
Ya, DPCD. That's probably built for Mopar by Carter, now part of TRW/Federal Mogul conglomerate. They [Carter Division] still make rebuildable fuel pumps and they're very likely the same as what you have from the factory.
PostPosted: Mon Nov 07, 2005 8:27 pm
If its the same thing I think it is,,,,they are easily rebuilt. I once rebuilt a 47 International fuel pump in under 10 mins by making a new diaphram out of a hunk of leather. (make sure you oil it up real good).\
You will need a good blade screwdriver, a pair of scissors, some sno-seal and a 1/2" box end wrench....and oh,yeah,,,,an old cowboy boot.
I like those old KB Outernationals,,,,,,,,,
PostPosted: Mon Nov 07, 2005 8:43 pm
The leather trick is cool and interesting, but a leather diaphragm won't survive well with today's politically-correct gasoline.
Those rebuildable pumps are easy to rebuild, and a very complete rebuild kit can be had from Antique Auto Parts Cellar in MA. Last time I bought was it was about $22. Includes a new diaphragm, new valves, new air dome gasket, all new springs, new mounting gasket, etc—all alcohol-resistance for long life with today's fuels. Very nice quality. The original pump on '60-'63 slant-6s was a rebuildable Carter number M2996s.
PostPosted: Mon Nov 07, 2005 8:46 pm
Not for slant-6s, they don't! There are still a few "Carter" rebuildable high-pressure/high-volume pumps available for V8s, but nothing with the specs or dimensions of the '60-'63 Carter rebuildable Slant-6 pump. Virtually all the Slant-6 pumps available on the market in any box (very few actual makers) have been crimped/sealed/nonrebuildable since '64.
PostPosted: Mon Nov 07, 2005 8:50 pm
I guess I should have added,,,"now kids...dont try this at home"
.....that pump did work all that summer though,,,,then the old KB and I parted company....
I saw her one last time though...in the Canmore Alberta Fire Departments No1 firehall,,,,on display. Long may you run,,,,,
450" straight six, 1barrel up draft Carter carb,Clark 5 speed non - synchro , straight cut gears...14000 miles.
PostPosted: Tue Nov 08, 2005 2:42 pm
Is the number embossed anywhere? As it sits it tested at 4 lbs but is displaying symptoms of a bad pump. Runs nice for as long as you would expect it to before the fuel bowl empties, then it completely loses horsepower, backfires through the intake, and you have to pump the gas to keep it running. Other than the occasional backfire the engine runs smoothly even though it has no power. Come to a stop, take it out of gear and it runs like a watch. Take off again, same thing. Compression is 115 to 135, 1,2, and 6 are the highest. Needle valve looks fine. Plugs show lean. I havent checked valve clearance yet, Ill be doing that tonight.
PostPosted: Tue Nov 08, 2005 2:44 pm
I should add that to my sig line, My other car has a rebuildable fuel pump too. Gotta love it.
PostPosted: Tue Nov 08, 2005 2:55 pm
Could be a clogged up fuel filter or fuel sock......
There's enough fuel volume under a low-load condition, but not otherwise.
PostPosted: Tue Nov 08, 2005 5:04 pm
Ohhh...y'know what? I just remembered, the fuel pump used on '60-'63 (maybe through early '64) in Canada is different than the US M2996S unit. The M2996s hasn't got the "DPCD" logo on it, but the Canadian-production pump does. Interchangeable as an assembly, but probably takes a different kit. If you pull it and clean it, you should find the actual mfr and the number stamped into the housing.
DS
PostPosted: Tue Nov 08, 2005 5:57 pm
Chryco instead of MOPAR.
I seem to remember early pumps having the telltale ring of slot head screws. I havn t seen one in a long time....
PostPosted: Tue Nov 08, 2005 7:05 pm
I thought of that, but I backflushed the relatively new filter with fuel through an old rag and didnt see any sediment to speak of... The carb is a recent rebuild, too...
PostPosted: Tue Nov 08, 2005 7:09 pm
DS
That makes perfect sense as this engine was also fitted with the cast iron Prestolite distributor. I tested this pump at 4 lbs and really didnt find anything all that horrible under the cap on the top, a little rusty water and that was it. I wish this problem was as simple as changing the pump, but I cant see that it is.
PostPosted: Tue Nov 08, 2005 8:45 pm
Yep, the cast iron Prestolite IBR-4203G distributor and the iron-and-steel "Auto Lite" (Prestolite) MDT-6017 direct-drive starter, too, I'll wager...
