It is currently Sat Nov 21, 2026 6:44 pm
Post new topic  Reply to topic  [ 69 posts ]  Go to page Previous 1 2 3 4 5 Next
PostPosted: Fri Nov 11, 2005 7:40 am
OK, perhaps, it looks like the company has still not improved its corporate responsibility position though, which is neither here nor there, I just picked up a BlueStreak coil and an AL111 condenser, let's see what happens. Stay tuned...
PostPosted: Fri Nov 11, 2005 8:53 am
No improvement. New coil, new standard points, new blue streak condenser, no change. I do not have a spare carburetor and as such I cannot eliminate it as a possible cause, but the more I think about it, the more it seems like I have a head crack. After the engine loses power, the idle vacuum drops, and slowly recovers over five seconds with no change in the idle quality and speed, and since I adjusted my valves, I have run the same circuit over and over, and the stumble begins ALWAYS in the same place, within 150 feet, you can almost set your watch to it. The car loses power, stalls, it will recover if you give it gas but still surges and limps all the way home unless I allow it to idle a little, then you can get on it again for a few seconds. Until that point, the car runs great. I am very close to deciding to remove my cylinder head and send it out for magnafluxing. but as soon as I do that, the engine is dead until I find another head.
PostPosted: Fri Nov 11, 2005 9:28 am
I just looked at the Kem instruction kit, it does not specifically mention "power valve" but it does show the economiser diaphragm, the triangular housing on top of the fuel bowl; on a hunch I removed the diaphragm and looked at it, everything looks fine, no cracks or folds. I blew out the vacuum passage and it is clear.
PostPosted: Fri Nov 11, 2005 10:21 am
I can't think of any oil companies who are fuzzy and lovable. :-(
PostPosted: Fri Nov 11, 2005 10:23 am
you are right about that.
I am going to go up the mountain and grab some fatter jets, I cant think of anything else aside from a new carb and/or head.
PostPosted: Fri Nov 11, 2005 10:32 am
65 is already very big. You don't need a bigger jet.
And I don't think you need a new head, either.
PostPosted: Fri Nov 11, 2005 11:34 am
well, here's what happened. I went out on a limb and grabbed a big fat #70 jet and threw it on, then went out on a test drive. Car is still showing the same symptoms, only this time the stumble came back much sooner, about half the distance I was seeing before. Once I got it home I ran it in gear at WOT until it stumbled and stalled. I removed the economiser cover and diaphragm, and looked in the hole. Well the fuel level is right at the pivot point for the economiser relay lever, that plastic jiggie clipped onto the side of the metering block. That's pretty far down, Id say. I could only push the float down about 1/8" before it hit the bottom. So either my float setting is still too low, or we have a problem with the fuel supply, but the pump is new and the pressure is constant. And get this, the exhaust is blowing clean out the tailpipe, even while it's stumbling. No strong exhaust smell either.
I think Ill pull the carb off and try to set that float a little more carefully...
PostPosted: Fri Nov 11, 2005 11:59 am
OK, float setting was at spec, actually the relay lever hinge point is higher up than it looked with that fuel in there. I did raise it a touch.
At any rate this car isnt going anywhere any time soon. Ive done all the easy things. I hoped that in a rush I could throw stuff at it and get the problem to go away, but whatever is wrong with this car isnt going to come off some shelf in Hamilton. Oh well, Ive got all weekend now to sort this out, and Ive got a bunch of good leftover parts that by rights I really should have had onhand for emergencies, anyway. I really wish I could see what my mixture and cylinder pressure was doing when it acts up, but that's not going to happen...
PostPosted: Fri Nov 11, 2005 2:03 pm
well, here's what happened. I went out on a limb and grabbed a big fat #70 jet and threw it on, then went out on a test drive. Car is still showing the same symptoms, only this time the stumble came back much sooner, about half the distance I was seeing before. .
Well you went richer and it happened sooner...........
I'd try going leaner........
PostPosted: Fri Nov 11, 2005 2:05 pm
What kinda float does the carb have??????
A bad float could sink and let too much fuel in.
The brass ones spring leaks, the plastic ones will actually absorb gas and sink..............
PostPosted: Fri Nov 11, 2005 2:13 pm
There are no brass Holley 1920 floats.
PostPosted: Fri Nov 11, 2005 2:15 pm
I've got a BBS, so I don't know..............
But I've had the absorb the gas problem with a Quadrajet..............
PostPosted: Fri Nov 11, 2005 2:26 pm
After a few decades' service, those Holley 1920 metering blocks just die, and nothing you can do will bring them back from the dead.
PostPosted: Fri Nov 11, 2005 2:30 pm
it's definitely still buoyant, but thanks for the thought. Im running short on them right now.
PostPosted: Fri Nov 11, 2005 2:33 pm
So youre saying if I track down an unused metering block, i can buy myself another 20 years? :lol: wouldnt that be sweet.
