It is currently Wed Jun 17, 2026 3:15 am
Post new topic  Reply to topic  [ 27 posts ]  Go to page Previous 1 2
PostPosted: Wed Nov 23, 2005 2:43 pm
It sounds like this is a "reman" engine. Major engine reman shops use the screwed on or riveted tags. If the engine was done by one of these places, most likely they took a cut of the top of the block, and this could remove the factory numbers.
 Post subject: numbers
PostPosted: Wed Nov 23, 2005 4:11 pm
thanks Charlie..i suspected something like that..too bad..it does have solid lifters so i guess its pre 1980 and it does look like its a rebuild..actually looks pretty good inside except it looks like no one ever changed the oil..
PostPosted: Thu Nov 24, 2005 6:42 am
The only things you need to be concerned about, as for the year, for parts, is: solid/hydraulic valve train, and cast/forged crank. Everything else will not make any difference in the year. You need to be more concerned with over/under sizes, that were used during the rebuilding process.
 Post subject: engine numbers
PostPosted: Thu Nov 24, 2005 9:19 am
how can i tell if its cast or forged crank?
PostPosted: Fri Nov 25, 2005 6:40 am
1975 and earlier used a forged crank, 76 and up is cast
-dave
what part of "illegal" is so confusing???
PostPosted: Fri Nov 25, 2005 7:07 am
No, actually, it's more complicated than that. The changeover from forged to cast was in the middle of 1976 production. All 1975 slant-6s have forged cranks, some 1976s have forged, some 1976s have cast, and all 1977-up have cast.
This is for US/Canada/Mexico production; other plants worldwide may well have stayed with forged right through to the end. (Argentina-Slantsixer?)
 Post subject: Get a cup of coffee Dan
PostPosted: Fri Nov 25, 2005 8:02 am
and all 1977-up have forged.
That is just plain wrong -
77 and up would be cast cranks.
PostPosted: Fri Nov 25, 2005 8:19 am
Whoops, bad things happen when I post before breakfast. :roll: I've fixed it.
The problem Valiant Effort is having, is, he doesn't know the year of the engine. I have been looking for my bearing book, so I could post the bearing sizes for the cast/forged crank, but it is misplaced.
The forged crank has a 1, 2, 4, main bearing width, slightly larger then 1 inch. The cast crank has a 1, 2, 4, bearing width less then 1 inch.
PostPosted: Tue Nov 29, 2005 12:03 pm
yes, that is true, I just go with the "76 up" statement when I am browsing the local yards to avoid getting a cast.
truth be told, I have have never had a crank or bearings fail anyway
-dave
PostPosted: Thu Dec 01, 2005 7:28 pm
thanks again charlie..I will measure them and let you know..
PostPosted: Fri Dec 02, 2005 1:27 pm
I also have a remafactured engine with a riveted tag on the block right side front just above the oilpan. It is painted black. My truck is a 67, but now the engine--block and/or head could be almost anything. I do have spark plug tubes--they are moist.
Guessing from the posts, I am looking for an earlier block with a forges crank, and a later head with hydralic lifters?
1967 D100 /225
Some of us catch on slow, and some of us don't.
