It is currently Tue Jun 16, 2026 12:24 pm
Post new topic  Reply to topic  [ 37 posts ]  Go to page 1 2 3 Next
PostPosted: Sat Nov 26, 2005 9:08 am
Hi All,
I have been talking to a guy about doing a batch of exhaust manifolds modified for turbo flanges. Here are some examples of what he has done for himself in a duster.
http://fueleconomytips.com/content/view/71/33/1/2/.
Anybody besides me interested? Here are the details so far:
1. Newer, ribbed exhaust manifold needed as a core.
2. You specify the turbo flange style/size
3. He will coat them with a hi temp titanium outer coating, and ceramic coat the inside ( He isn't sure that he can get the ceramic into all the nooks, but will give it a try.
Whatta ya think? Interested? Next, the manifold/fuel rail post.
PostPosted: Sat Nov 26, 2005 9:26 am
Hey, that looks just like mine :shock:
Except for the split t4 flange on mine :wink:
Not really interested myself, but any idea on the price?
PostPosted: Sat Nov 26, 2005 9:46 am
Pricing... Well, I don't know just yet an exact price. But, I can give some sort of ball park, I suppose. Mike initially made me an offer for some head porting and prep work, plus a modded exhaust manifold, for around $700. I suspect that the manifold, just for me would be around $200-$400, if I was to separate it out. I suspect if we can get a batch together, it will be on the cheaper end of the spectrum. I haven't heard back from Mike yet on this, and I don't want to put words in his mouth, so I will refrain from speculating any further.
Also, he has the right equipment/supplies for cast iron welding, plus the coating/ceramic materials, etc. I don't get the feeling that this will be a hasty, crummy job. Since he has done it before, he knows what "right" will be with it.
Hope this helps.
PostPosted: Sat Nov 26, 2005 9:57 am
PostPosted: Sat Nov 26, 2005 9:59 am
Well...not necessarily. Since he has done it before, he can do it again...the same way. Maybe it's right, and maybe it ain't. All we have to judge by? One story and a handful of tiny pictures. We really need more info on this guy's skills and knowledge before it's clear whether he's a good $$ risk.
 Post subject: Okay, questions?
PostPosted: Sat Nov 26, 2005 10:03 am
Dan, and others,what do you want to know? If you post your questions, we can get them to him, in one organized list, and you can decide if it is for you or not.
 Post subject: prices
PostPosted: Sat Nov 26, 2005 12:15 pm
From Mike. I will see if I can invite him to our group.
-Turbo exhaust manifold, exhaust ports opened up to gasket size and flowed into the log, adapter plate welded for turbo of choice (I have the TI-TII and TIII/Holset turbos here) at a 3 degree angle for pan rail clearances, ceramic coating on the inside as far as I can reach, hi-temp titanium coating on outside, $200. Less porting, $140. Bare manifold with no coatings, just the adaptor, $100. Prices include the supplied manifold.
I have 2 different ceramic thermal barrier coatings that I use, both water based.
I gave up on owning older Mopars when I could no longer afford/find parts. I'm now a Turbo Dodge man (stuff is just as plentiful and cheap on these as they were on the L-6 Dusters a decade ago).
For the price, the Slanter's can't go wrong. I guarantee my work, if any problems (other than the manifold cracking unless they want to shell out an additional $35 to have it magnafluxed) arise, I'll fix, replace, or refund.
PostPosted: Sat Nov 26, 2005 2:59 pm
make sure im reading all of this correctly? for $200 he supplies the manifold // ports it // ceramic coats it // and does the flange to mount a turbo??????
well I screwed that up I have to supply the manifold. anyone got one of these newer style ribbed manifolds they want to sell to me? or know where i can get one from?
count me in.
dont compromise customize
boost IS a substitute for cubic inches
PostPosted: Sat Nov 26, 2005 3:52 pm
Theres a guy that lists new repro exhaust manifolds on ebay occasionally for like $150
PostPosted: Sat Nov 26, 2005 4:05 pm
ill check into that / im sure someone on here has one. or maybe the guy doing this stuff has a spare he will sell me. I sent an im togmader asking these questions.
but I will try ebay as well
interesting 8)
Cuda Progress :D
The dart as it sits now :(
PostPosted: Sat Nov 26, 2005 4:06 pm
ill check into that / im sure someone on here has one. or maybe the guy doing this stuff has a spare he will sell me. I sent an im to gmader asking these questions.
PostPosted: Sat Nov 26, 2005 4:14 pm
http://www.1aauto.com/1A/ExhaustManifol ... 042/310581
There are could be better prices out there, but this is cheap, and may work. Hard to say, as it may be crappy chinese stuff.
Quote from their site
Our aftermarket manifolds are some of the highest quality replacements on the market!
This cast iron manifold has been designed to eliminate the faults of the original Chrysler design. Designed for use with all emissions and non-emissions vehicles.
Specifications
2 bolt exhaust flange
Direct replacement
Replaces original manifolds that are cracked from thermal expansion and contraction
Corrosion resistant
Strengthened and redesigned in the vulnerable areas of failure
Now you can buy a high quality exhaust manifold for less than 1/3 the price of the dealer. REPLACE your broken, warped, or cracked one now with this great fitting, alternative.
Dealer list ~ $395.00
It is built to strict quality control standards and is a great replacement that has substantial cost savings over a dealer unit.
Backed by manufacturer's limited LIFETIME warranty. For as long as the original purchaser owns the vehicle, in the event this manifold should fail due to manufacturing defects, we will REPLACE the part free of charge. Warranty is limited to replacement cost only (excludes shipping charges). Failure due to improper installation, or improper use is not covered. Please keep your invoice for proof of this warranty.
PostPosted: Sat Nov 26, 2005 4:16 pm
Yup thats the same place I was refering to that sells on ebay. I *think* someone on here got one before and said they liked it... it was either here or .com forums
PostPosted: Sat Nov 26, 2005 6:07 pm
looks really interesting, although the stock manifolds have been known to crack without a turbo. 200 bucks would be worth a shot, though.
-james
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 4 guests
