It is currently Fri Jan 02, 2026 6:33 am
PostPosted: Tue Dec 06, 2005 9:55 am
Car Model: 71 Dodge D100 64 Plymouth Valiant Wagon
Sometimes I have too much time to dream. Would a slant six fit into a '53 Dodge pick-up? The engine bay looks a little narrow.
What do you think?
Joe
Joe Hoppe
71 D100 225 Super Six 727 AT on 2008 Crown Vic CopCar frame
64 Valiant Wagon 225 904 AT 3:23 8.75"
PostPosted: Tue Dec 06, 2005 10:31 am
I know I have seen a /6 transplanted in to a 57 Dodge pickup. I imagine the are pretty close to the same size.
81 1/2 Ton, 2 WD,225, 4 Sp With O/D
81 3/4 Ton, 4 WD, 360, 727
70 1 Ton, 4 WD, 225, 4 Sp
PostPosted: Wed Dec 07, 2005 6:17 am
Thanks, Nate.
Still dreaming,
Joe
Joe Hoppe
PostPosted: Wed Dec 07, 2005 7:42 pm
If I was gonna try to put a slant in an earlier pick-up, Id look for a post-61 /6 Town Wagon or Panel to rob parts from- prolly easier said than done, though! :lol:
Brian (Valianator)
'65 Valiant V100 170/T-flite
'82 D150 225/4-speed
'65 Dart 225 4 door
'68 Dart 225 4-door with Valiant front clip (future project)
 Post subject: It will fit
PostPosted: Thu Dec 08, 2005 5:33 pm
You can install a slant/6 in a Pilothouse Dodge, it will fit. You may have to massage the passenger side inner fende, but it will go. You should be ok on the firewall, but double check it. I'm installing a slant/6 in my 50 Plymouth wagon with similar size concerns, but it can be done.
Life is good!
PostPosted: Mon Dec 12, 2005 9:08 pm
Car Model: 1964 Valiant
Consider reversing the radiator support. Some install the longer
236-251-265 "big block" six by moving the radiator forward.
The '48-53 trucks are attractive, they have shortened wheelbase
and cross-steering for tight turning, tighter than some current
small cars. Some 4wd builders add cross-steering to late model
trucks for better trail handling. Pilot-House trucks had a lot of
innovation, they were the most advanced trucks of their era.
Users browsing this forum: Ahrefs [Bot], Bing [Bot], Google [Bot] and 13 guests
