It is currently Thu May 21, 2026 8:55 pm
PostPosted: Thu Jan 19, 2006 7:39 pm
Here's the situation: I've got a BBP 7.25 rear end from a '73 318 Dart.
My '65 Valiant has a SBP 7.25 rear end from a '74 Scamp in it.
Can I just swap the axles/brake assemblies from the BBP rear to the rear that's already in the Val? That would be easier than swapping out the whole rear end assembly, and I know the rear that's there now is nice'n'quiet.
Thanks!
Brian (Valianator)
'65 Valiant V100 170/T-flite
'82 D150 225/4-speed
'65 Dart 225 4 door
'68 Dart 225 4-door with Valiant front clip (future project)
PostPosted: Thu Jan 19, 2006 7:53 pm
No, brakes are entirely different.
Slant Cecil
PostPosted: Thu Jan 19, 2006 8:17 pm
I know. I was thinking of the swapping the entire brake assemblies- backing plates and all. Will it work if I do that, or is something else different?
Brian (Valianator)
'65 Dart 225 4 door
PostPosted: Fri Jan 20, 2006 5:10 am
No. The axle tube ends are completely different. The bearings on the axles are different too. SBP axles/ brakes have 4 mounting holes in the backing plates. BBP axles/brakes have 5. :shock:
PostPosted: Fri Jan 20, 2006 5:35 am
swamp the whole assy-- remove the leafs & rear as an assy-- roll it out & roll it in the 65 -- remove some lines first & your done!!!!!
PostPosted: Fri Jan 20, 2006 9:58 am
Got it. Will swap the whole assembly.
Thanks, fellas!
Brian (Valianator)
'65 Dart 225 4 door
PostPosted: Thu Jan 25, 2007 7:35 pm
OK, this brings up another question. Can a carrier assembly and ring & pinion from a SBP 7.25 be swapped into an LBP housing and axles?
David Kight
'62 Valiant Signet, White
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Thu Jan 25, 2007 8:10 pm
I would assume so - www.ringpinion.com doesn't differentiate years.
PostPosted: Fri Jan 26, 2007 7:03 am
I swapped my 65 sbp 3.23 gears into my 75 bbp assembly with no issues. It took mebbe 2 hours and required no special tools but I had to be innovative with drifts and 1/2"drive extensions.
PostPosted: Fri Jan 26, 2007 7:45 am
I guess the specific question is will a Sure Grip from an early A - say a 65 Dart, fit properly into a LBP 7.25? If the gears won't fit it's a deal breaker but if the sure grip fits it's icing on the cake.
David Kight
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Fri Jan 26, 2007 4:04 pm
A Quick Answer to Valiantor' S question:
No, The Axle tubes are different and the Axles are different.
THe early type has No C Clips. The Later type does; Bearings are different
too.
To accomplish What you are trying to do Swap the entire Housing and Axle assembly.
PostPosted: Fri Jan 26, 2007 6:24 pm
Only the housing ends changed to accomodate the big bearings. I have a 65 SG unit in a 75 lbp housing in my car. Carriers and gears all swap although I can't vouch for the real early ones. I have never yet seen a 7 1/4 with c-clips.
O==\=/==O
"A mechanic is Somebody."
- Jim Preston
PostPosted: Fri Jan 26, 2007 7:14 pm
Thanks. That's what I suspected but it's nice to have some confirmation.
David Kight
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Sun Jan 28, 2007 6:52 am
Sorry About the BAd info,
I must have confused the Later 7.25's with the 8.25's
PostPosted: Sun Jan 28, 2007 7:46 am
Well, the 8.25 would be more desireable but the 7.25 in question is essentially free. The sure grip is available at reasonable cost and I already have the 3.23 gears. I will be able to put the rear axle together for very nominal cost and since I am unlikely to seriously stress it I don't anticipate any serious problems with it. If it fails then I'll address the issue at that time.
David Kight
'98 Dodge Dakota
'06 Jeep Liberty
