It is currently Thu May 14, 2026 7:34 am
PostPosted: Wed Jun 27, 2001 11:54 am
I need a good "small" (e.g. Carter BBD/smallblock) 2bbl air cleaner baseplate. The space constraints in the '62 A-body engine compartment mean in order to run my 2bbl, I need to cut the carb hole out of a 2bbl baseplate and "paste" (weld) it onto a 1bbl baseplate so I can use the 1bbl air cleaner assembly that clears the engine bay. Doug or anyone?
DS
redbear@vrx.net
PostPosted: Thu Jun 28, 2001 11:16 am
: I need a good "small" (e.g. Carter
: BBD/smallblock) 2bbl air cleaner baseplate.
: The space constraints in the '62 A-body
: engine compartment mean in order to run my
: 2bbl, I need to cut the carb hole out of a
: 2bbl baseplate and "paste" (weld)
: it onto a 1bbl baseplate so I can use the
: 1bbl air cleaner assembly that clears the
: engine bay. Doug or anyone?
Dan,
Are you still looking for one of these? Let me know, if you just need a 2bbl air cleaner base, I'm sure I can find one in my garage.
Let me know,
Wes '78 Volare
<A HREF="mailto:wes.moeller@compaq.com">wes.moeller@compaq.com</A>
: DS
