It is currently Sun Jun 14, 2026 7:09 pm
 Post subject: Engine Tune Up.
PostPosted: Wed Feb 08, 2006 9:55 pm
Ok, I´m still having problems with my car after going to electronic ignition, first thing is that after replacing dist, now I can move more easy my car in cold mornings or with cold engine.
Now I got this other problem, no matter how I carburate the car and how much I move the dist, my car runs roughtly, engine shakes a lot, is worse now when I used points ignition!!!.
Any help here? I need to admit that I´m a shot patience person when things don´t go the way I want.
Mopar Muscle is well defend by Slant Six!
Valiant Duster 1971
PostPosted: Wed Feb 08, 2006 10:07 pm
You reverse the wires on the coil or distributor?
PostPosted: Wed Feb 08, 2006 10:22 pm
I don´t whink i reversed wires to distributor, I will check wires to the coil, and double check wires to distributor.
Valiant Duster 1971
PostPosted: Wed Feb 08, 2006 10:37 pm
1-5-3-6-2-4 is the correct firing order.
Have you adjusted the valve lash?
PostPosted: Sun Feb 12, 2006 4:35 pm
Car Model: A couple slant six mopars and other mopars
I think we are having the same electronic ignition issues. My car does not idle soothly at all. When placed in drive it has a vibration. convx4@yahoo.com Bill S
PostPosted: Sun Feb 12, 2006 4:46 pm
Ok, problem solve awhile, the problem was in the carb. I just needed to fix the mix and set the engine to idle at 820-850 RPMS, also I needed to ground well the ignition module.
Valiant Duster 1971
