It is currently Wed May 20, 2026 11:02 pm
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 7 posts ]
PostPosted: Sat Jun 30, 2001 10:20 am
I want to buy one of those liquid holding tools used to cc combustion chambers. I think it's called a 'burette'. I was talking with a machine shop about doing the final 45 degree seats when I get done porting my /6 head, and they said they would charge FORTY DOLLARS to measure EACH CHAMBER!!! Well needless to say, I said something equivalent to "no". $69 to grind the seats is more than enough. Besides, if I had my own tool, I could cc all the chambers, plus use it on other engine projects whenever I wanted. How much do these things usually cost? Thanks.
PostPosted: Sat Jun 30, 2001 10:40 am
I have to do that to my head too, so I can calculate my final compression ratio. I got a piece of lexan and drilled a small hole it in and put some grease around the chamber to stick it water tight.poked a spark plug in there, and grabbed a "horse" syringe from my local Feed/Hay store. Total out of pocket cost $10, and I had to tell the clerk I was using it for my own habit...
*grin*
Good luck,
-DusterIdiot
res0aus2@verizon.net
PostPosted: Sat Jun 30, 2001 1:53 pm
: I want to buy one of those liquid holding tools
: used to cc combustion chambers. I think it's
: called a 'burette'. I was talking with a
: machine shop about doing the final 45 degree
: seats when I get done porting my /6 head,
: and they said they would charge FORTY
: DOLLARS to measure EACH CHAMBER!!! Well
: needless to say, I said something equivalent
: to "no". $69 to grind the seats is
: more than enough. Besides, if I had my own
: tool, I could cc all the chambers, plus use
: it on other engine projects whenever I
: wanted. How much do these things usually
: cost? Thanks.
tim: you can buy a cheap plastic berette from summit racing equipment. i think they are about $20..........chad
beardliz@msn.com
PostPosted: Sat Jun 30, 2001 9:30 pm
There is a tools article in the August 2001 Hot Rod magazine. Someone is selling a "kit" with the burette and some other things for $139 (???) Seems quite spendy to me. The $10 syringe in the other post may be an acceptable inexpensive alternative.
cfield@ll.net
PostPosted: Sat Jun 30, 2001 10:05 pm
: I have to do that to my head too, so I can
: calculate my final compression ratio. I got
: a piece of lexan and drilled a small hole it
: in and put some grease around the chamber to
: stick it water tight.poked a spark plug in
: there, and grabbed a "horse"
: syringe from my local Feed/Hay store. Total
: out of pocket cost $10, and I had to tell
: the clerk I was using it for my own habit...
: *grin*
That is the way I do it.
Will
: Good luck,
: -DusterIdiot
slantsix@netzero.net
PostPosted: Mon Jul 02, 2001 2:49 pm
: cost? Thanks.
I called Summit, and they said Comp Cams has them for $39.95 . I'll try there.
PostPosted: Mon Jul 02, 2001 6:05 pm
: I called Summit, and they said Comp Cams has
: them for $39.95 . I'll try there.
I just went and picked up a new 60cc Horse Cathater Syringe and a piece of plexiglass and a tube of blue food coloring for a grand total of $3.78 out of pocket. I needed to replace my old syringe and with that equipment it was easy to find my chambers are 52.5 cc's each with very little variation (less than 1/10th) due to casting flash I ground out of my chambers.
Good luck,
-DusterIdiot
