It is currently Tue Nov 17, 2026 6:12 pm
 Post subject: 2 barrel adaptor plates
PostPosted: Mon Feb 13, 2006 10:48 am
I am researching the 2 barrel adaptor plate on the one barrel intake. Is the opening in the manifold big enough to handle the new two barrel carb or would it be better just to get the two barrel intake? Thanks for your help. David
PostPosted: Mon Feb 13, 2006 11:12 am
Arrrrgh. We've hashed over this question many, many times over the past few years.
Short answer: Adaptor plates are dumb and halfâssed. Do it right, use or make a 2bbl intake.
PostPosted: Mon Feb 13, 2006 11:30 am
What Dan said. Don't bother trying to stuff two barrels of intake flow through a one barrel opening because you'll just wind up with one barrel's worth of flow.
"Former Owner" of '65 Barracuda, 225, Auto, MP 2bbl intake, MP cam, Dutra Duals. Presently Moparless.
PostPosted: Mon Feb 13, 2006 12:18 pm
For a cheap (maybe) alternative to sourcing a two barrel intake, see here:
http://www.slantsix.org/forum/viewtopic.php?t=15873
I didn't do the best job of precision engineering the placement of all the holes and whatnot, but the point is it is doable.
PostPosted: Mon Feb 13, 2006 2:42 pm
Yes, it is better to have the 2bbl intake. BUT, the 2bbl carb with an adaptor on the 1bbl intake is a step up from the 1bbl carb. http://www.cardomain.com/ride/658846/5
82 D150 Slant6 Shorty
PostPosted: Mon Feb 13, 2006 2:51 pm
Disagree.
PostPosted: Mon Feb 13, 2006 2:55 pm
I guess a good 2 bbl on an adapter would be better than a crappy 1bbl,
but the 2bbl intake is the "best" way to go.
But it is just my opinion... :wink:
PostPosted: Mon Feb 13, 2006 3:03 pm
I agree with this. But, a good 1bbl is better than a good 2bbl on an adaptor. Crappy carburetors of any description are...well, they're crappy!
PostPosted: Mon Feb 13, 2006 3:15 pm
I did get the same performance out of my Carter YF 1bbl as my 5210 2bbl. But, I get better mpg from the 5210 on same intake.
Users browsing this forum: Bing [Bot], DuckDuckGo [Bot], Google [Bot] and 3 guests
