It is currently Thu May 14, 2026 11:05 am
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 8 posts ]
PostPosted: Tue Jul 03, 2001 1:23 pm
Ok, How do i go about making the pin diameter of the 2.2L KB's jive with the 198cui /6 rods? (Which i still REALLY NEED A SET)
OR
Anyone got a good set of oversized higher CR 225 pistons?
http://hackme.dhs.org
cralt@hackme.dhs.org
PostPosted: Wed Jul 04, 2001 6:58 am
: Ok, How do i go about making the pin diameter
: of the 2.2L KB's jive with the 198cui /6
: rods? (Which i still REALLY NEED A SET)
: OR
: Anyone got a good set of oversized higher CR
: 225 pistons?
well. buy 6 cima/mahle forged pistons (intended for vw type 1, 2 and 3 engines...theres loads of shops for those in states.) 88 mm or 87 mm and put 198 rods, with a bushing for 22 mm pistonpin.
1. you get hi-quality forged pistons
2. you get higher compression
3. you get floating pins
4. you get those pistons for dirt cheap. 100 bucks, or less
5. you get faster revving engine
6. you get lots of weight off the rotating masses.
7. sorry my english
http://homepage.mac.com/jyrie
jyri.eramaa@jwt.fi
PostPosted: Wed Jul 04, 2001 12:08 pm
: OR
: 225 pistons?
They should be the same size already. On mine, we honed the rod and made them full floating, steel on steel. If I do another one, I'll just have the pins pressed, floating them was a "just in case" because we didn't know what the deck height would be. Dennis
aschumers@aol.com
PostPosted: Wed Jul 04, 2001 2:07 pm
: well. buy 6 cima/mahle forged pistons (intended
: for vw type 1, 2 and 3 engines...theres
: loads of shops for those in states.) 88 mm
: or 87 mm and put 198 rods, with a bushing
: for 22 mm pistonpin.
: 1. you get hi-quality forged pistons
: 2. you get higher compression
: 3. you get floating pins
: 4. you get those pistons for dirt cheap. 100
: bucks, or less
: 5. you get faster revving engine
: 6. you get lots of weight off the rotating
: masses.
: 7. sorry my english
That sounds great! What does the compression ratio come out to be with the VW pistons?
dartman225@webtv.net
PostPosted: Wed Jul 04, 2001 9:11 pm
: OR
: 225 pistons?
hey CrALT. i have a set of jahns forged dome pistons .060 oversize with pins i'll let you have them for what i've got in them which is $165.00 and you pay shipping. they are brand new. let me know if your interested? or maybe some of you other guys might be.
buddy_37@hotmail.com
PostPosted: Thu Jul 05, 2001 1:02 am
: That sounds great! What does the compression
: ratio come out to be with the VW pistons?
well...the piston sits -2 mm under the deck...
if i remember correctly, its somewhere 10 the compression...damn i had to calculate it...
the pistons are light, sorry i dont have the weight now, but i will get it when i am in garage...
the machinist i used took a bushing out of a volvo, but i think its not a problem to locate those...
jyri
jyri.eramaa@jwt.fi
PostPosted: Thu Jul 05, 2001 9:24 am
: They should be the same size already. On mine,
: we honed the rod and made them full
: floating, steel on steel. If I do another
: one, I'll just have the pins pressed,
: floating them was a "just in case"
: because we didn't know what the deck height
: would be. Dennis
Dennis, I checked the Keith Black website and it lists the KB239 as having a .9009 pin. The 198 rod uses a .9012 pin, right? What does floating mean and how is it done? THANKS! Darrin
PostPosted: Thu Jul 05, 2001 3:08 pm
: Dennis, I checked the Keith Black website and
: it lists the KB239 as having a .9009 pin.
: The 198 rod uses a .9012 pin, right? What
: does floating mean and how is it done?
Don't sweat the .0003 size difference here, we are basically talking about cutting a hair into 10 even strips, picking one, then slicing that in 1/2 for the per side hole size difference. (.00015)
Depending on how your rod's "small-end" holes "land" in the mfg. tolerance range, there is a potential issue here IF you are using a "pressed pin" set-up and the tolerances "stack-up" the wrong way, ie, a small pin in a large rod hole. (I never really run into this seeing that production machinists tend to stay to the "small side" of an IDs tolerance range and the "large side" on ODs., the old saying being that it is easer to take more metal off then to put metal back on!)
If you go "full floating", ( where the pin moves freely in the piston *and* the rod's small end hole)the rod's pin hole will need to be opened-up even more then the .9012 size it is theoricly at now. Bottomline is this combo is "right there" size wise and will only need a final hone to "dust" the small end into perfect size for your choosen set-up. (pressed or full float)
