It is currently Tue May 12, 2026 11:31 pm
Post new topic  Reply to topic  [ 39 posts ]  Go to page Previous 1 2 3
PostPosted: Sun Feb 26, 2006 10:19 am
Reviving an old post. I was just looking at TF Patty's E-Bay store, and he has these filters listed.
http://cgi.ebay.com/ebaymotors/MOPAR-To ... 7976163387
PostPosted: Sun Feb 26, 2006 12:04 pm
If I was to add a filter to the tranny line, I'd just plumb in an remote spin-on filter adaptor and use spin-on oil filters.................. (but not FRAMs..)
And throw in an add-on cooler at the same time.
PostPosted: Sun Feb 26, 2006 1:12 pm
You don't need it on your 64. I was posting this for those, with the earlier cars, who want to keep them original.
PostPosted: Sat Mar 04, 2006 6:51 am
OK, this brings up a question. I have a 62; the tranny pan has a drain plug and there is an external filter in one of the cooling lines. I would like to get rid of the external filter and switch to the later internal filter. I have a scrap transmission but I don't know its vintage. It is, however, a cable operated tranny but the pan has no drain plug. It does have a screen strainer rather than a filter. How can I easily determine if that pan will accomodate the internal style filter? I also have a later tranny from a column shift car but i don't want to cannabalize it, at least not yet.
David Kight
'62 Valiant Signet, White
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Sat Mar 04, 2006 7:44 am
The internal strainer, pan w/drain plug and external filter was used through '63. The internal 2-port filter was used '64-'65, and the slightly modified pan for filter clearance and w/o drain plug was used from '64 on up.
So, you need a '64-up pan and a '64-'65 2-port filter.
PostPosted: Sat Mar 04, 2006 9:11 am
OK, got that. The spare pan I have does not have a drain plug but what does "slightly modified" mean? Comparing the 2, the original pan has a drain plug and the bottom if the pan is completely flat and smooth; the pan off of the spare parts tranny does not have a drain plug and the bottom has an embossed circle, no more than 1/4 inch deep. Is that the one I need?
David Kight
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Sat Mar 04, 2006 1:03 pm
Yep, the "embossed circle" pan is the one you need. You may want to take the opportunity to install a drain plug kit in it.
PostPosted: Sat Mar 04, 2006 1:09 pm
Cool. Thanks a bunch.
David Kight
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Sun Mar 05, 2006 5:42 pm
Car Model: 1962 Lancer 770
Yeah, he has a few. I actually ended up selling mine to him and just converting to the later style filter. Seemed a lot easier and simpler.
Like Dan said, use the pan with the little "circle" pop-out and you're good to go. The filter bolted right into my 62 valve body no problem at all.
A drain plug sure would be nice to add while you have it out!
MJ
