It is currently Wed Nov 11, 2026 12:09 am
PostPosted: Sun Mar 05, 2006 7:01 pm
I have power discs on my Duster. I'll be swapping to manual actually. but for now, the motor dies when i press the brake and its park. idling at about 800rpm. even more so when its in drive with the brake.
any suggestions? The line from the intake to the booster doesnt leak. But i believe the master cylinder is shot...possibly could the booster just turn into a massive vacuum leak and kill the motor? :shock:
Daily Driver 72 'Cuda
74 Duster /6
http:www.goodysgotacuda.com
Last edited by GoodysGotaCuda on Sun Mar 05, 2006 7:25 pm, edited 1 time in total.
PostPosted: Sun Mar 05, 2006 7:03 pm
Unhook the hose from the booster and plug it. Then see if it still stalls. The diaphragm inside these things can sometimes start to leak.
82 D150-225/727
02 Dakota-3.9/5 speed
PostPosted: Sun Mar 05, 2006 7:24 pm
[quote="Jeb"]Unhook the hose from the booster and plug it. Then see if it still stalls. The diaphragm inside these things can sometimes start to leak.[/quote
I'll have to try that. The booster pumps a couple times fine after the motor is stopped. But i think the seals on the m/c are shot...so maybe its somewhat related.
74 Duster /6
PostPosted: Sun Mar 05, 2006 7:26 pm
Also, when i shut the motor off with the key. (usually at about 800rpm). It shakes the car pretty good. Possibly ignition related or anything...or check the motor mounts?
-Mike
74 Duster /6
PostPosted: Sun Mar 05, 2006 8:06 pm
It sounds like you have abruptured brake boostyer diaphragm.. THis happened to me once on my 84 Ford van and the symptoms are exactly as you describe.
The leak coul be leaning you motor out to the point that you are having a lean backfire when the motor shuts off.
Users browsing this forum: Amazon [Bot], Bing [Bot] and 4 guests
