It is currently Wed Nov 18, 2026 1:21 am
 Post subject: 61 Godge Lancer.
PostPosted: Mon Mar 27, 2006 8:20 pm
61 Godge Lancer. You can buy it reasonable before I start. 220.00.!!! Located in southeast Washingtin State. Desert country. Dry cliamate so very minimal rust.
Subject vehicle,...is a 1961 Dodge Lancer. Complete car with a clear title. It is a 4 Door that has a near perfrct body. Good tires, Needs paint, but only due to fade. Clean car with good upholstery.
The engine rotates with a heavy spot. I assume a bad rod bearing.
I looked it over today and it appears to have to be pulled to even get the pan off. 3 speed on the tree.
Which procedure for pulling engine is best? Engine tranny together? Do I need to pull radiator? Any shortcuts? Gl440
PostPosted: Mon Mar 27, 2006 8:34 pm
If it's got a 3-speed manual trans with the shifter on the steering column, it's probably a '62. The '60-'61 cars with manual transmission had the shifter on the floor.
Pulling the engine and trans together means you needn't find a way to hold the trans up...!
 Post subject: 62 Lancer
PostPosted: Tue Mar 28, 2006 6:11 am
I stand corrected, it is a 62. I just wanted to see if there was a quicker way than standard pull. I will leave tranny in. It appears tight, so radiator out. Gl440
PostPosted: Tue Mar 28, 2006 8:50 am
It's only 4 more bolts, a couple of clips, and the speedo cable to pull the tranny. The job is a ton easier if you do.
David Kight
'62 Valiant Signet, White
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Tue Mar 28, 2006 4:39 pm
Will Do,!! Thanks G.
