It is currently Thu May 21, 2026 11:11 am
PostPosted: Tue Mar 28, 2006 3:57 pm
What is a good pick for a 10" drum conversion?
Will a MC made for 9" front drums work, or should I only look for ones made for 10" brakes?
It's a 63 Signet /6 with 10" front drums (from a 66 Dart) and 9" rear drums
I'm looking only for the iron type.
PostPosted: Tue Mar 28, 2006 4:36 pm
Any drum-brake master cylinder will work fine. For best results, it should contain a residual pressure valve at both outlets (this can get difficult...they stopped using them for '73 when they redesigned the wheel cylinder seals.)
Are you trying for a dual-pot master cylinder or a single-pot type?
PostPosted: Tue Mar 28, 2006 4:40 pm
Dual pot.
I am getting a new one from NAPA.
I can get this one today 4736338 (for 72 Dart with 9" drums)
or get 4736308 tomorrow (72 with 10" drums)
The 9" one has 15/16 bore
PostPosted: Tue Mar 28, 2006 4:51 pm
When you get new wheel cylinders for cars older than a 73, do they have the new wheel cylinder seals in them?????
PostPosted: Tue Mar 28, 2006 5:07 pm
I can get this one today 4736338 (for 72 Dart with 9" drums) or get 4736308 tomorrow (72 with 10" drums)
Might as well get the 10" unit.
Yes.
PostPosted: Tue Mar 28, 2006 6:54 pm
Choose your master cylinder by piston/bore diameter, and configuration/physical compatibility, not by "power vs. manual". The master cylinder generally doesn't know whether it's bolted onto a booster or straight onto the firewall. About the only special issue to be aware of: There's a random mix of good info and nonsense in Condran's book.
If the mbc for 10" brakes has 1 1/16 bore and the 9" unit has 15/16 bore, or vice versa, would the 15/16 bore be preferable for drum brakes?
PostPosted: Tue Mar 28, 2006 7:52 pm
Either. Do you want a harder-to-press brake pedal that doesn't travel as far (the 1-1/32" one), or an easier-to-press pedal that travels farther (the 15/16" one)?
PostPosted: Tue Mar 28, 2006 10:26 pm
I'm not sure what I'd prefer. I'll think about it.
I read somewhere that people like 15/16" for the more common disc brake conversion.
Users browsing this forum: No registered users and 18 guests
