It is currently Mon Nov 16, 2026 10:25 pm
 Post subject: Cam help?
PostPosted: Sun Apr 02, 2006 3:25 pm
Car Model: '23 T-bucket
Looking at these two on Summit website. http://store.summitracing.com/Compare.a ... RS-E470521
Anybody care to comment for a 2000-2400 pound car, 225 and two-barrel, auto trans?
Roger
PostPosted: Sun Apr 02, 2006 3:59 pm
Your link doesn't work. (goes to summit, but doesn't compare anything)
What 2 part numbers are you comparing?
PostPosted: Sun Apr 02, 2006 6:34 pm
Hmmmmm......Must need a cookie from Summit for it to hook up for anybody else.
Here; ERS-E470621, and ERS-E470302. Both of them are Erson cams. One is touted to be for 2000-5000 rpm, while the other has a bit more duration, but same lift.
Roger
PostPosted: Sun Apr 02, 2006 7:50 pm
I'd go for the
ERS-E470301
because you have an automatic transmission.............
Unless you're going to be manually shifting the automatic, the transmission shift points are more suited for the lower rpm range..........
