It is currently Mon Nov 16, 2026 10:25 pm
 Post subject: Cam help?
PostPosted: Sun Apr 02, 2006 3:25 pm
Car Model: '23 T-bucket
Looking at these two on Summit website. http://store.summitracing.com/Compare.a ... RS-E470521
Anybody care to comment for a 2000-2400 pound car, 225 and two-barrel, auto trans?
Roger
PostPosted: Sun Apr 02, 2006 3:59 pm
Your link doesn't work. (goes to summit, but doesn't compare anything)
What 2 part numbers are you comparing?
PostPosted: Sun Apr 02, 2006 6:34 pm
Hmmmmm......Must need a cookie from Summit for it to hook up for anybody else.
Here; ERS-E470621, and ERS-E470302. Both of them are Erson cams. One is touted to be for 2000-5000 rpm, while the other has a bit more duration, but same lift.
Roger
PostPosted: Sun Apr 02, 2006 7:50 pm
I'd go for the
ERS-E470301
because you have an automatic transmission.............
Unless you're going to be manually shifting the automatic, the transmission shift points are more suited for the lower rpm range..........
Users browsing this forum: Ahrefs [Bot], Bing [Bot], Google [Bot] and 3 guests
