It is currently Sun Oct 18, 2026 5:45 pm
Post new topic  Reply to topic  [ 1379 posts ]  Go to page Previous 1 … 67 68 69 70 71 … 92 Next
PostPosted: Wed Oct 12, 2016 4:33 pm
OK, now you're getting close, I think I'm gonna put the Webber's back on (LOL )!!!!
Destroked 300 (272ci)
PostPosted: Wed Oct 12, 2016 4:45 pm
I have a few more ideas to try.. i need to water the money tree first though. Webers are one of them. :-)
PostPosted: Sun Jul 09, 2017 10:32 pm
Car Model: 1965 Dart 270 w/ 66 Valiant front clip
Do you have any pictures of how your oiling system is setup?
PostPosted: Tue Jul 18, 2017 8:19 pm
They were all on here until photobucket broke it.
Try this
http://s299.photobucket.com/user/hyperp ... t=3&page=4
And this
http://s299.photobucket.com/user/hyperp ... t=3&page=5
Also watch this video.. it might help.
https://youtu.be/P81lzr_Owwk
Also i should be at the wilkesboro race this weekend... stop by and see it in person at empire chrysler sat morning.
 Post subject: Ruster Update 11/19/17
PostPosted: Sun Nov 19, 2017 5:05 pm
Hi guys,
I just got done with the engine teardown..
I put the car away after making it to the 3rd round of the fall mason dixon race.
Turn out i have a spun rod bearing as i suspected.. and also i found out why i was getting water in the oil..
There were 2 cracks in the bottom of #6 cylinder and 1 crack in #5 cylinder..
So i need to get a new block and another molnar rod.
PostPosted: Mon Nov 20, 2017 5:17 pm
SSRN National Champion
Gary Bruner was able to order a single rod from K1 this week if you cant find a molinar
PostPosted: Mon Nov 20, 2017 5:40 pm
any ideas on why the bores cracked,,
did you just get 5 and 6 cylinders too thin on the over bore?
PostPosted: Mon Nov 20, 2017 5:49 pm
Did you fill your block when you did the overbore? If so how deep?
PostPosted: Mon Nov 20, 2017 6:34 pm
Do you mean with hard blok?
No I did not.. i think i will put more time into this block.. probably a partial hard block fill as well.
I have some research to do.
I am not sure why it cracked... but this block lased quite a while. 5+ years without too many issues until this.
Lots of passes too.
PostPosted: Mon Nov 20, 2017 6:37 pm
Good to know Ron,
I was able to get a single rod from tom before.. i just need to match the big end and little end weights.
PostPosted: Tue Nov 21, 2017 4:10 am
Do you remember what clearances you were running?
PostPosted: Tue Nov 21, 2017 3:38 pm
Stock.. prolly 0.001-0.0015
Machine shop and I agreed to double that rod clearance to 0.003 on the rod journals.
Mains were fine.
A bit of thrust bearing wear from stalling the conv. so much.. i believe this one does not have the anti balloon plate.
PostPosted: Tue Nov 21, 2017 3:47 pm
Yep that should be good. Wonder why it spun? :( Which rod was it? Probably one of the center 4 I'd guess.
I'm sure Ruster will debut next year better than ever! :D :D
PostPosted: Tue Nov 21, 2017 4:54 pm
Yep it was #4.
At least i didnt shoot a rod through the block or oil the track down...
PostPosted: Wed Nov 22, 2017 3:18 am
I thought that Pittsburgh track racers had to sign a form that they were required to oil down a track at least once each year? :P You are way behind, Greg.
