It is currently Wed Nov 11, 2026 6:50 am
PostPosted: Sat Apr 18, 2009 11:50 am
It sounds like you’ve got it figured out now. You can carefully trace all those extra wires to make sure they are extras and remove them. I’ve pulled a trash can full of wires from under the dash of almost every car I’ve ever bought. They can accumulate a lot of radio, speaker and fog light wires in 40 years and they can all be trouble later also.
Danny
 Post subject: update...
PostPosted: Sun Apr 26, 2009 7:28 pm
status: I've narrowed down the most accurate wiring diagram, reconnecting the original ammeter as their wires(black/red) were still connected to their locations in the bulkhead disconnect-inside car.the black was still connected from firewall to alternator. i have cleaned all connections and replaced all connections(used male quick disconnects per dealer). i do have one wire that's just been hanging around coming from the t location and going to the oil pressure switch. where is the oil pressure switch if anyone knows... i've looked in haynes and chilton hard cover and apparently overlooking it. the last wire to be replaced on bulkhead is the j spot/gray to coil negative side. let u know what happens... peace, katt
fenomenalkatt!!!
'67 Dart "Sandy"
225/904
PostPosted: Sun Apr 26, 2009 8:11 pm
Oil pressure switch is under the oil filter attached to the oil pump housing. The electrical terminal faces the passenger's foot well.
PostPosted: Tue Apr 28, 2009 1:45 pm
[quote][/quote]thanks wjajr now i have to different diagrams as i mentioned and the one from haynes seems to be misleading, for the wire coming from the j position on bulkhead disconnect/firewall side. the one from haynes has that wire going to going to the relay, the diagram i downloaded has a gray wire going to the coil/negative. do u know which is right(i believe the download) and more importantly what gauge is the wire. i am at the finish line almost
fenomenalkatt!!!
'67 Dart "Sandy"
225/904
PostPosted: Tue Apr 28, 2009 2:24 pm
PostPosted: Tue Apr 28, 2009 2:41 pm
PostPosted: Tue Apr 28, 2009 3:04 pm
yes i'm using that diagram and it goes no where on both sides. so i'm done with the engine compartment other than checking all other connects. now i'm disecting the inside where all the extra wires are including a fake alarm system. go figure.
fenomenalkatt!!!
'67 Dart "Sandy"
225/904
