It is currently Sat Nov 21, 2026 11:13 pm
Post new topic  Reply to topic  [ 26 posts ]  Go to page Previous 1 2
PostPosted: Sun Jul 11, 2004 5:57 pm
The previous post was from me. Had to go to backup computer, and forgot to log on. One other thing of note. Due to manufacturing tolerances, I have yet to find a 170 at zero deck. All have been between .010-.025 down the hole. Also the factory head gasket, was a steel shim type, at .022.
 Post subject: Not alone...
PostPosted: Mon Jul 12, 2004 4:46 am
heckshemi, I'm with you; I've been doing a "paper" long rod 170, and trying to get the numbers to work out. I can't wait to hear that little motor sing! And hey, someone said the block is 50# lighter, so great handling, too!
The deck height misprint is everywhere, like panic says, but the block really is an inch and a half shorter, as verified by Charlie and Hypervaliant.
The 2.5 stuff looks good to me;
86-88 rod = 6.179 c to c, 1.014 big end width, 1.969 journal
(Newer rods are shorter because they did the common block trick)
Not as strong as your Carillo or as light, but at least they're pure :wink:
2.5 turbo piston = 1.335 comp height
Small end is a match, they're designed for each other.
This piston has a dish, don't know the depth yet.
This combo ends up .0115 positive, which should be an easy mill for whatever deck you want, reducing the dish volume at the same time. A little dish left will hopefully promote a good burn, while increasing crown surface area for a little extra push.
The crank issue has held me back because of the cost, but if Doc's idea really works, stand back!
Doc, when did you use that journal trick? No durability/oil control problems?
O==\=/==O
"A mechanic is Somebody."
- Jim Preston
PostPosted: Mon Jul 12, 2004 10:24 am
I have seen a "journal in a journal" done on a couple of different cranks, one was a V8, the other was an inline 4. (never on a SL6)
I've never run one myself so I don't know about the durability issue.
The key would be to maintain the connecting rod side clearance for oil control, there is enough meat on our SL6 crank to do that with ease.
I would also put a radius in the corners to reduce the chance of cracks starting.
PostPosted: Wed Jul 14, 2004 6:10 am
Maybe someone typo'd it: 9.68 was suppoesd to be 9.068?
That would make more sense - the 170 would have NO compression with the piston that far down.
PostPosted: Tue Nov 08, 2005 2:47 pm
Hey heckshemi, any progress with the 170?
I was thinking of building high revving long rod turbo 170.
With quick calculating vw bug 88mm piston and a Ford 5.932" rod would be close to stock height.
PostPosted: Wed Nov 09, 2005 1:12 pm
Progress has been slow. I got the crank machined. It turned out real nice. The rods are bushed. The block has been bored .104" over. I've got most of the parts together. Working on a "special" head now.
I'm thinking the '64 Dart may be to heavy for the 170 so I'm also building a 225 for it. The 170 will go in a '61 Valiant.
I'll try to post some pics.
Franklin
'61 Valiant
PostPosted: Fri Nov 11, 2005 1:19 pm
I bought a set of 6 Ford 4.6 V8 Carrillo rods. 8) Pic
Talked to my machinist yesterday. He wanted to enlarge the big end to match original slant size and use slant rod bearings. That way I could use stock crank.
Edit: Changed a bigger picture
PostPosted: Fri Nov 11, 2005 9:36 pm
Progress has been slow. I got the crank machined. It turned out real nice...
Did you weld and grind or simply grind the new journal inside the current one?
PostPosted: Mon Nov 14, 2005 6:50 am
Mike Jeffrey runs Chevy rods with the Slant crank machined down in the middle for a journal-in-journal.
I am contemplating a similar buildup with ~6" rods and pistons from a Mopar 2.0-2.4L.
I like the looks of the Carillo 4.6 rod. I can't make out the C-C length on your sheet though.
I also like the thought of 2.2L or 2.5L rods with closer big ends to the Slant dims.
PostPosted: Mon Nov 14, 2005 9:04 am
Center to center is 5.932. I was looking Wiseco 88mm pistons. Listed to Toyota 3TC.
PostPosted: Mon Nov 14, 2005 10:09 am
I had them machined down the middle as "journal in a journal" as you suggested, Doc. Turns out they were nascar rods with honda size journals so there was plenty of meat on the crank for side support.
Franklin
'61 Valiant
Users browsing this forum: Google [Bot] and 13 guests
