It is currently Wed Nov 25, 2026 2:53 pm
 Post subject: No passing gear
PostPosted: Wed Aug 25, 2004 3:11 pm
When I floor my Duster at 60 MPH to pass somebody, it does'nt kickdown to 2nd gear. Is it supposed to do this. My D-150 is the exact same way. Floor it around 50 and it will dropdown a gear. Above 60 it does nothing.
82 D150-225/727
02 Dakota-3.9/5 speed
 Post subject: gearing
PostPosted: Wed Aug 25, 2004 3:39 pm
Depends on your rear gear, sometimes you can be going too fast for the trans to kick down. You could do it manually. You may need to adjust the throttle pressure linkage a little. Mess with that and see what happens, give it some more pressure (push back on the trans arm)
PostPosted: Thu Aug 26, 2004 2:41 pm
It has 2.76s out back, so is their any risk of overevving my motor if I pull it down manually?
82 D150-225/727
 Post subject: speed
PostPosted: Thu Aug 26, 2004 3:15 pm
that depends on the speed at which you do it :lol:
keep it in second, then drive up to just below the power band limit, note your mph speed, that`s the speed at which you can safely kick it down and still have it pull some more for passing
stock trans should have a governor dis-allowing ridiculous manual downshifts, so downshift away!
 Post subject: Re: speed
PostPosted: Thu Aug 26, 2004 3:19 pm
"dis-allowing" :lol:
I LOVE that word!
D/W
If it ain't broke, fix it!
PostPosted: Thu Aug 26, 2004 5:09 pm
:lol:
