It is currently Sun May 17, 2026 9:36 pm
PostPosted: Wed Apr 13, 2005 2:44 pm
I'm going to replace the standard hood latch on Aaron's '74 Dart Sport with a cable release hood latch. Where does the cable pass through the firewall? There are no holes or plugs. Got any pics to show me?
Jerry
PostPosted: Fri Apr 15, 2005 12:40 pm
No one has one of these????
PostPosted: Fri Apr 15, 2005 6:47 pm
The inside hood release is very uncommon on an A-body. None of mine have ever had that option.
I'll take a look at my factory service manual later. Sometimes they are good to show things like this, sometimes not.
PostPosted: Fri Apr 15, 2005 10:12 pm
There should be a dimple a little larger than the cable you'll have to drill a hole through. I put an inside hood release on my 73 Dart Sport when I had it, but don't have any pics. A trip to a junkyard may provide you with an example.
Steve G.
 Post subject: Remote, etc.
PostPosted: Sat Apr 16, 2005 8:52 am
From memory only, I think it passes through the firewall below and to the right of the steering column. Correctly installed, you should have plenty of cable to even make a mistake. The valiant I just parted out had one, and it was an aftermarket item. Guy drilled a hole through the firewall, put one of those "O" ring protectors around the hole or maybe even some plumber's black putty and it looked like a factory job.
