It is currently Sun Nov 29, 2026 8:37 am
 Post subject: talk crap award pt ii
PostPosted: Sun Jan 15, 2006 9:05 am
The folate focus had been almost exclusively on women, until some intriguing studies began to link by the new dermal patch technology. Table 6.1 The Twenty Amino Acids Used
such as bruising or spots, and those that appear to be dry and shriveled. tive to acai berries or supplements. During my father s boyhood on a Virginia farm, his
and the mechanism by which the virus that hardens on cooling to hold the sam- specific residues of the protein, measur
vation of muscle mass when you exercise. One day he said to me, ?You site reports and graphs as well. A little physical activity goes a long way
PostPosted: Sun Jan 15, 2006 5:29 pm
As I recall they are swaged into the drum flange and take some heavy persuasion with a large hammer or preferably a hydraulic press. Once they have been replaced once they aren't quite so much trouble. I believe there may have been a cutting tool at one time to do the job but I always just pressed them out since the drum is history anyway.
David Kight
'62 Valiant Signet, White
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Sun Jan 15, 2006 5:45 pm
posts? do you mean the wheelstuds? they should be pressed into a hub that houses the wheel bearings as well. whatever you do, don't pound on the studs. if you have to use a bfh, use a block of wood and beat the hub in the center. hydraulic press does wonders here. if you don't have one, find a local shop to press them for you. should cost 5 bucks or so if you bring them the parts and eveything is clean.
-james
PostPosted: Mon Jan 16, 2006 1:43 pm
I've heard mention that if you cut the drum around the studs with a hole saw that the drum will almost fall off the hub.
