It is currently Sat Nov 28, 2026 7:46 am
PostPosted: Fri Feb 10, 2006 7:10 am
1. drum seal, federal mogul part. Which side faces backing plate, fuzzy cork or metal rim?
2. Pitman seal, federal mogal part. Which side faces ground, rubber or coil spring side?
Thanks for all the help.
PostPosted: Fri Feb 10, 2006 1:44 pm
Car Model: '23 T-bucket
James....will start with Q-2
The spring side should almost always face the lubricant side of whatever youre installing it in. That is the case for your pitman seal, too. Robber out, spring in.
Q-1......Without knowing exactly what the seal looks like, I'd say metal out. Seals are designed in such a way that if pressure were to build inside the container, that the pressure would push against the sealing surface so as to place more contact against the shaft that is supposed to be sealed.
Roger
PostPosted: Mon Feb 13, 2006 8:52 am
Thank you.
