It is currently Wed May 13, 2026 11:52 am
PostPosted: Wed Mar 22, 2006 12:42 pm
Does anyone know of a good source for stock replacement proportioning valves or better yet, rebuild kits for them?
I don't want to go to a non-stock style, and 30+ year old O-rings make me nervous.
PostPosted: Wed Mar 22, 2006 12:59 pm
AFAIK there are no rebuild kits, nor are there secret stashes of new ones. They are not hard to disassemble, clean and "rebuild" with new premium O-rings; the harder part would be chasing down the premium O-rings. Plumbing supply house items will not be acceptable. I'd probably use Neoprene A/C O-rings.
What kind of car are you working with? What kind of rear brakes have you got?
PostPosted: Wed Mar 22, 2006 2:17 pm
One of the brake places, either mpbrakes or ssbc (wasn't there one other major one?) had stock style ones that would fit in same location w/same bracket
If you have no luck at the brake places try finelines or classictube, inlinetube or other line vendors. Like i said, I know I saw them, just not positive where.
 Post subject: proportioning valve
PostPosted: Wed Mar 22, 2006 2:18 pm
Thanks Dan.
It's a '71 Plymouth Satellite w/ stock disk/drum brakes; the origonal PV valve I've got in there is working just fine, but as since everything else in the entire system is new and/or rebuilt, it's probably the weakest link.
While the O-rings are probably not hard to find, the plastic differential pressure switch insulator is a bigger concern, and I was just wonderning if somebody made them and so I could buy a spare or a kit.
I've a book at home to tell me fluid/material compatibilities - I believe natural rubber is one of the preferred materials for DOT3, but I don't have the book in front of me. [I've been running DOT5 for years w/o trouble but have not tested viton compatibility with it; some know combinations swell badly.]
