It is currently Thu Jul 02, 2026 10:14 am
 Post subject: Weber 32/36 Jets
PostPosted: Sun Jun 18, 2006 2:49 pm
Car Model: 1964 Dodge Dart GT - 2 door hardtop - 225 Slant 6
So, I've got this weber, and I'm putting it on a 225 six.
What would be a good way to jet this carb (preferably for a more economical stand point).
I have found a jet set (32/36 Jet Kit 6cyl. DGV) that has the following jets:
Main: 150, 155, 160
Idle: 75, 80, 85, 90
Sec. Idle: 60, 65
Pump Jet: 60
Air Corrector: 155, 160, 180
Thanks for the help!
1964 Dart GT
225 "Super Six" w/ Weber 38 DGES
GM HEI, Nippon Denso 80A Alternator and high torque mini starter
PostPosted: Sun Jun 18, 2006 4:53 pm
I have this jet kit myself and have been playing with the jetting off and on for the past year. This is a good kit, but I have also purchased individual smaller jets as well. I tried to jet it as lean as possible without damaging anything. I have been able to get 22mpg on a very lean jetting with backing down the timing. I don't recommend doing this for an extended period of time (long story). The carb comes already jetted pretty close for a stock engine and exhaust. The best way to get good mileage with this carb is to keep your foot out of it to prevent the second barrel from opening up. I'm still jetted a little lean and getting 19mpg reliably and I get on it from time to time during my commute.
Brian
Flyin' Brian
"Sixy Beast"
PostPosted: Sun Jun 18, 2006 9:12 pm
Brian
If I may ask, can you adjust the starting point of the secondary on these?
PostPosted: Mon Jun 19, 2006 5:51 am
I have not tried to do that, and to be honest, don't want to. The second barrel starts to come open (quickly when it does) at about 2/3-3/4 full throttle. After driving with this carb for a while, you can tell when you are nearing the transition point to the second barrel.
I would think that it might take some doing to change when that second barrel opens. But then again, I am admittedly lacking with experience.
Brian
Flyin' Brian
"Sixy Beast"
PostPosted: Mon Jun 19, 2006 7:05 am
Brian
