It is currently Thu Nov 19, 2026 10:41 pm
 Post subject: tire size on a 66 dart
PostPosted: Thu Jul 27, 2006 7:11 am
I just got my 8 3/4 in last night. I am running 15x7 American racing Torque thrust 2's. I bought the wheels and tires used and I think the tires are too big for the car. There is a limited amount of room. What size tire will fit on a 66 dart w/o cutting the wheel well lip? The tires that are on there are 235/60/15
Thank you for any info you can provide
William
PostPosted: Thu Jul 27, 2006 11:28 am
I have 225/50R16's on my '66, which are only a little smaller. They currently fit with no problems, although I did have to bend back the inner lip on the front fenders. You don't need to do any cutting to do this mod, and it's not even visible.
"Mad Scientist" Matt Cramer
'66 Dart - turbocharged 225
PostPosted: Thu Jul 27, 2006 12:25 pm
I had 235/60R15s in the back of my '66 Dart no problem. The key is the correct offset wheel for the rear end you're using. When I had an A-body 7 1/4 and an A-bdy 8 1/4 Dodge cop car wheels fit perfectly. With cut down C-body wagon axles in the A-body the tires were pushed outward 3/8" and would rub on corners so I had a pair of wheels made with 1/2" more backspacing. Your wheels probably only have 3.5" of backspacing and that's not enough.
PostPosted: Thu Jul 27, 2006 10:05 pm
I have a '65 Dart, I am running 235/60x15 tires with stock chrysler 15x7" steel rims. No rubbing at all.
