It is currently Tue May 12, 2026 10:52 am
PostPosted: Thu Sep 07, 2006 10:37 am
Any advice on a reasonable priced welder that is an ALL around for a project car.
PostPosted: Thu Sep 07, 2006 10:46 am
http://www.millerwelds.com/products/mig ... matic_135/
This will do most automotive work that comes up. If you frequently weld material thicker than 1/4" you'll need a bigger welder. I've been using one for years and it's never let me down. Just keep a few spare contact tips on hand and you should have years of trouble free service.
PostPosted: Thu Sep 07, 2006 11:18 am
I can't even find the name of mine, but if you're interested in a stick welder I'd recommend looking for one with continuously variable settings rather than click settings like the common Century buzz boxes. When you get into thin metals you don't want to be locked into a one-size-fits-none heat.
A long time ago when Century poor men's welders were $149.95, I paid $225 for a continuously variable welder.
PostPosted: Thu Sep 07, 2006 11:20 am
I have a lot of friends who weld for our student design teams on campus, and they all say to forget MIG and just go with a TIG. I understand the technical advantages of TIG, but in terms of learning curve, how much harder is the actual process of welding than MIG? I've had my hands on a MIG a few times and it seemed like something I could pick up if given sufficient practice time, but I've never actually tried TIG.
Edit: I just looked at TIG prices... wow... there's at least one compelling argument to go w/ MIG.
Used to own:
'82 Dodge D150
Erson 270 Cam, O/S valves, mild port work, ~9.5:1 compression
Currently fighting with an '85 VW Cabriolet
My other passion
PostPosted: Thu Sep 07, 2006 11:45 am
What about this
deleted link
PostPosted: Thu Sep 07, 2006 12:05 pm
If you do find that you need a bit more power go for the MillerMatic 185. Not sure if its still made, but it lays down one of the nicest welds I've seen.
PostPosted: Thu Sep 07, 2006 12:25 pm
What about this
http://www.homedepot.com/...
Your linky no worky. What brand/model were you lookin at?
Used to own:
'82 Dodge D150
My other passion
PostPosted: Thu Sep 07, 2006 12:36 pm
What about this
HD carries Lincoln looks like the one that $349 might do well. The Link gets you to the tool page and then go to "welders"
Although I copied it when I was on the welders page
 Post subject: Lincoln SP135
PostPosted: Thu Sep 07, 2006 1:28 pm
I tried to save some money, but ended up wasting it - I bought an Oxy acetylene rig and a small budget stick welder - The Oxy/Ac rig takes more finesse than I give it, and the Buzz box stick welder (mightymite) is way under powered. I have not used either one since I bought the Lincoln SP135 Mig/Fluxcore wire feed welder. The SP135 with CO2 Argon mix was easy to use. I have welded floorpans, exhaust pipes/mufflers, angle iron fuel cell stand, rear seat hold down clips in the 61 Valiant. I wish I would have skipped the OXY/AC and the stick welder and just made the Lincoln SP135 my first.
PostPosted: Thu Sep 07, 2006 2:42 pm
I have a MIG (110v) I got from Harbor Freight. (one of their 1/2 price sales).
Used mostly for exhaust work, and light work (1/8", sometimes 3/16").
Don't bother with flux-cored wire. You're essentially a mini-arc welder and you have lots of slag to clean up.
BTW, once you find settings that work, write them down.... :wink:
PostPosted: Thu Sep 07, 2006 3:56 pm
I have a strong suspicion that hobart welders are identical to miller on the low end of the price scale. They have the same output/performance, visible identical except for coloring. Definately stay away from oxy welding and stick if you plan on doing sheet metal. If for some strange reason you do go with an arc/stick welder I would suggest the thinnest rod you can find. I've had luck with 5/64 E6013 rods, but I believe they can also be had in super thin 1/16". Some of the lincoln welders I've seen looked a little on the flimsy side. Last year I needed to replace my welder and purchased the millermatic 135 that was mentioned. The welder was over $500 and the large Co2/Ar cylinder was another 160. I haven't had any problems that were the machines fault. Mig isn't very forgiving on rusted or dirty (painted) metals at low voltage settings. Tig takes some skill for thin metals I hear the Tig-p (pulse) machines can do thin easier but cost more. Tig is the best method in terms of strength, but for 95% of auto welding mig is the way to go.
PostPosted: Fri Sep 08, 2006 5:25 pm
http://www.millerwelds.com/products/mig/millermatic_135/
Very good product for the avarage user. And if your going to do body work this type welder is need for sure.
If you have plans of fabrication work ( like aluminum intakes or headers) then a tig is the way to go for sure. But the tig want do body work it gets to hot.
The miller Joshie225 listed is very good al around and will do body work with ease & can even pull off fabing a set of headers its just better with a tig to that. I dont think aluminum work is very good with this type welder though. Some say you can but a Tig is they to go for aluminum for sure.
Jess
PostPosted: Mon Sep 11, 2006 9:47 pm
Thirty years ago, I asked myself that same question. I bought a gas setup with Smith gauges, body and tips. I never looked back since then.
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 1 guest
