It is currently Wed Nov 27, 2024 12:39 pm
PostPosted: Thu Oct 26, 2006 7:28 am
PostPosted: Thu Oct 26, 2006 8:18 am
Welcome aboard! I'm sure you'll find some good information here.
Your list looks like a good start. You should get a factory service manual for the van, as well
has an overhead single Camshaft
No, it is not an overhead cam. The single cam is in the block.
the engine won’t turn it self of before
That sounds like it has been "hot-wired" and/or hacked to put in some electronics - and that box is fried! Check the ignition switch and associated wiring carefully. You may have to rebuild the ignition system.
Very good photos! Those will help. Already, we can see issues with the carburetor, throttle return spring, vacuum lines ... But nothing that can't be repaired.
PostPosted: Thu Oct 26, 2006 8:50 am
Ummm, your wiring looks.....interesting :?
Fint på nøtterøy eller?
PostPosted: Thu Oct 26, 2006 9:17 am
Cam is in the block k. :)
The wiring is not my work, I havent done anything on this van yet except for pulling out the regulator and taken some pictures :p
Nøtterøy er knall i dag, bortsett fra regnet.
PostPosted: Thu Oct 26, 2006 9:23 am
Ok, well, if you need it, I could probably drop by sometime.
I can give the moral support needed, if nothing else
PostPosted: Thu Oct 26, 2006 12:24 pm
Thanks alot man :)
But il try not to bother you unless something really goes to hell :p
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 9 guests
