It is currently Sat Jun 13, 2026 1:52 am
PostPosted: Thu Jun 28, 2007 4:54 am
I want to do the t5 swap in my valiant. Does anyone have one of the converted bell housings they want to sell?
If not, I need to start looking for the right bellhousing to start from. Is it 75-87 4 spd overdrive bellhousings that were in aspens/volares, trucks and vans? Is that the only one that will work? Can other bells be modified easy enough?
69 valiant
PostPosted: Mon Jul 02, 2007 9:38 pm
What mods need to be done to the bellhousing to fit a T5?
Im thinking of using my 80 volare as a jump off point for a scratch built rod, but I think the t5 would be a better tranny than the stock auto in the volare...
S.
1980 Volare Slant
PostPosted: Tue Jul 03, 2007 5:36 am
Hi, I have one. I can send pics if you pm me your regular email address. I live in Raleigh, NC. Mine id perect, not a speck of rust, and the bell is polished and all threads are perfect. Gonna try a 727 and put in a 833OD is only reason I will lelt it go.
rock
'64d100
PostPosted: Sun Jul 08, 2007 9:09 am
Is that the same as an A body 833OD? And I can bolt a 5 speed to it? Where do those trannies come from? ( T-5s)
PostPosted: Mon Jul 09, 2007 9:53 am
A T5 will not bolt to an A833 bellhousing. the group buy bellhousings have a plate bolted to the back with the ford T5 bolt pattern on it.
PostPosted: Mon Jul 09, 2007 11:00 am
OK group buy was before my time. Who made them? Andy F?
PostPosted: Mon Jul 09, 2007 11:42 am
to the best of my knowledge it was Dart270 that set it up. however there are no more being made. they do show up from time to time on ebay.
you'll need alot more then the bellhousing to make this work. this is hardly a bolt in deal. you need to make or modify a tranny crossmember, you need an adapter for your crank hub for the t5 pilot bearing. clutch linkage is easy with the mcleod hyd. throwout bearing but expensive. and if your not already a stick car you'll need some clutch pedals. and you got to have a driveshaft made. make sure you know what your getting into. it add$$ up quick.
