It is currently Sun Nov 22, 2026 6:41 am
PostPosted: Sat Sep 01, 2007 8:25 am
Is there anywhere to put the connection for the oil pressure gauge other than on the pump itself?
PostPosted: Sat Sep 01, 2007 8:49 am
You can drill and tap the main oil galley, a cast-in tube that runs from the oil pump cavity to the rear of the block. This is briefly described in Doc's article on block preparation. Here is a link to the article
http://www.slantsix.org/articles/dutra- ... blocks.htm
Later blocks have a boss cast in near the rear reinforcing web which makes an ideal place to mount a pressure sending gauge. I believe you need a 1/8 NPT threaded hole but you should double check that. Once drilled it's hard to undrill.
David Kight
'62 Valiant Signet, White
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Sun Sep 02, 2007 3:54 am
theres a tee that you buy so you can still use the light and the gauge
Users browsing this forum: Amazon [Bot], Bing [Bot], Google [Bot] and 3 guests
