It is currently Wed May 13, 2026 12:34 pm
PostPosted: Sat Jul 28, 2001 2:30 pm
Slant Six Cylinder Head and the Revised Combustion Chamber by Doug Dutra.
http://slantsix.org/articles/combustion-chamber/sl6-combustion-chamber.htm
webmaster@omnipages.com
PostPosted: Sat Jul 28, 2001 6:36 pm
The new GM Vortec 4200 has a similar bore and
stroke to the 225 slant six ~ 3.66 x 4.01" - both are undersquare stroker inline sixes. But, the new head design makes a big difference, 270 horsepower stock ( 275 ft pounds at 3,600 RPM with most of that available at 1,200 RPM ).
I believe it comes with a 7 quart oil capacity, it's designed to be a work horse for trucks and SUVs.
How does GM improve air flow to help top end, but get that kind of low-end torque from a motor about the same size as the slant six ?
I'd sure like to see a slant head like the new Vortec :)
: Slant Six Cylinder Head and the Revised
: Combustion Chamber by Doug Dutra.
