It is currently Fri Nov 20, 2026 5:31 am
 Post subject: Why is it....
PostPosted: Thu Sep 13, 2007 10:12 pm
Site Admin
That something always comes up just before a Race?
The plate on my Offy was giving me grief. When I put it on my mill table, sure enough, it's warped.
Now where am I going to get one of these in less than a week?
Does Offenhauser even have a web site? Google sure can't find it!
:shock: :shock: :shock:
CJ
PostPosted: Thu Sep 13, 2007 10:43 pm
Can you mill it flat?
PostPosted: Thu Sep 13, 2007 10:53 pm
6 Pack Dart
CeeJ
Come over to my place, I think you will find that I have just what you need :shock: You should call me more often with your issues.
PostPosted: Fri Sep 14, 2007 12:17 am
www.offyparts.com
is who you want - if you were over here there is two interesting manifolds I might have let you test :shock: check your mail
PostPosted: Fri Sep 14, 2007 5:37 am
Site Admin
I'll scoot down there Saturday Fopar. Thanks!
As far as milling it flat, the tapped holes are now misaligned. That makes the studs lean toward each other. To pull the spacer, I had to remove the studs. Milling the part wouldn't solve that.
Offyparts isn't Offenhauser's site. It's another reseller. They don't list the correct plate either.
Clifford doesn't list a plate on their web site, but then I don't think their internet storefront shows any small parts.
CJ
PostPosted: Fri Sep 14, 2007 7:59 am
Offenhauser Corporation
5300 Alhambra Ave
Los Angeles, CA 90032
tel (323) 225-1307
It is a family-owned business; they haven't got much of a switchboard, so you may have to try a few times to get through.
PostPosted: Fri Sep 14, 2007 8:05 am
Site Admin
Thanks Dan!
I'll give them a ring today and see if I can get a part number.
I'll post it if I'm successful!
CJ
 Post subject: Re: Why is it....
PostPosted: Fri Sep 14, 2007 9:58 am
You think you've got it bad for the Medford trip? My radiator is at the shop to be rodded out, I'm ordering up radiator hoses, heater hoses, water pump, belt and coolant overflow bottle. Evidently the original spring hose clamps won't last 40 years. Most were broken right in half, but still stuck to the hose. I'm lucky I didn't loose a hose last weekend when I drove over 200 miles.
If you have a mill why don't you fly cut the plate and straighten it out?
CJ
PostPosted: Fri Sep 14, 2007 12:01 pm
6 Pack Dart
His mill isn't that big
PostPosted: Fri Sep 14, 2007 12:22 pm
Site Admin
It'll travel 7-1/2" The trouble is My vise opens to 5-1/8"
There are ways to work around that, but none of them are pretty.
I could bolt a smaller block to the bottom of the plate with the manifold screws, (Counter Sunk) and fly cut the face. I have enough travel, but would need to make two passes with my large cutter.
The biggest surface I've faced so far was 4-1/2" Square. I did that in two passes with the medium cutter. Another option would be to use a large mill, in my case a 3/4"
All lots of work.
At least the surface speed would be much faster than when we cut that steel shaft keyway. It loves making aluminum chips! :D
CJ
