It is currently Sun Nov 29, 2026 10:29 am
PostPosted: Fri Oct 12, 2007 8:51 am
OK, I've been searching for over an hour and can't find my answer.
I thought I read somewhere that an early A-body K member (63-66) is the same whether it's a 6 or a V8. Is this true?
If not can I put a 77 /6 in my 66 that has a V8 K member?
Old info I thought I knew, sorry?
Thanks in advance
PostPosted: Fri Oct 12, 2007 9:00 am
Yes, the early K-members are the same for \6 and V8 engines.
PostPosted: Fri Oct 12, 2007 9:45 am
You'll want an early A-body oil pan and pickup tube on the '77 engine.
What transmission do you plan on using?
PostPosted: Fri Oct 12, 2007 10:18 am
I have the manual overdrive on the 77, Will use the crossmember
PostPosted: Fri Oct 12, 2007 11:05 am
The '77 cross member won't fit the '66, but the '66 cross member and mount will bolt to the '77 trans.
