It is currently Wed May 27, 2026 4:43 pm
 Post subject: Manual Steering Box ID
PostPosted: Sun Oct 21, 2007 8:01 pm
I picked up an aluminum steering box at a local yard, and was wondering if there's any way to identify it. It's real tight and smooth, so I may install it in the future if my power steering pump keeps leaking. How do I figure out the ratio?
Thanks ahead!
225 Cubic Inches of Iron-Head American Muscle
225 bored .040 /.100 off block, Schneider Cam 224@.050~ .480 lift - Stock valves, blended bowls, Offenhauser intake with 500 Edelbrock carb
PostPosted: Sun Oct 21, 2007 8:26 pm
The ratio is almost certainly 24:1. Almost all of them were. You can determine the ratio by counting turns of the input shaft from one lock to the other.
5¾ turns = 24:1
4½ turns = 20:1 <--my favourite
3½ turns = 16:1
