It is currently Wed May 20, 2026 2:39 am
 Post subject: Electronic distrbutor
PostPosted: Tue Oct 23, 2007 4:48 pm
Hello, I need some advice on replacing my stock distributor to electronic. I have a 1966 225/6. It has a super six setup with Dutra Duals and 2 1/4 dual exhaust. It is all stock other than the S/S & duals. Can anyone suggest a good setup and what other parts, electronically, need to be replaced with dist. I read when you convert you no longer use the ballast. Down the road I want to put a Erson cam custom grind for street use with automatic nothing wild. I would like to purchase new parts to hopefully avoid problems. Any advice is greatly appreciated. Thanks, Ed
PostPosted: Tue Oct 23, 2007 6:27 pm
If your distributor is in good shape, the easiest thing to do is put a pertronix ignition inside it (replacing the points)
PostPosted: Wed Oct 24, 2007 7:34 am
I used an electronic distributor from a later Slant six and a HEI module from a GM car. I have been happy with the setup and I no longer use a ballast resistor. Also you can gap your plugs at .045
http://duster318.freeservers.com/tech/hei.html
1966 Signet
Turbo Slant Six
Users browsing this forum: Google [Bot] and 29 guests
