It is currently Mon May 18, 2026 12:26 am
PostPosted: Wed Oct 24, 2007 2:01 pm
at the risk of revealing my ignorance regarding capacitors. how do you tell which end is the positive or negative or does it matter. I'm about to do the repair to fix my gas and temperature gauge problems and the diagrams at allpar seem to say there is a positive and negative but the ones I've purchased at radio shack do not indicate a positive or negative...vic
PostPosted: Wed Oct 24, 2007 2:47 pm
I sent you a PM. Let me know if you need more help.
PostPosted: Wed Oct 24, 2007 5:40 pm
Electrolytic capacitors, the ones that look like little cans, do have a polarity which will be marked on the outside of the can. The ceramic capacitors which loosely resemble M&Ms are not polarized. You can install them either way with no ill effects.
David Kight
'62 Valiant Signet, White
'98 Dodge Dakota
'06 Jeep Liberty
