It is currently Fri Nov 20, 2026 5:09 am
 Post subject: rear main seal
PostPosted: Sat Feb 23, 2008 10:11 pm
I have replaced the rear main seal on my van twice, and it still leaks. Is there any speedy sleeve for this 1979 slant 6 or another kind of seal that works better? has any one else had this problem?
1979 dodge sportsmen camper van
PostPosted: Sun Feb 24, 2008 5:54 am
Hi Kit,
In a hurried moment I almost put one of the seals in backwards once. VERY easy to do, are you certain the lip is pointing the right way? I ask cause I have never had one fail.....oh did you also use a torque wrench to tighten the aluminum seal block under the crank rather than guess at if it was tight enough? It's more important than many torques..
rock
'64d100
Users browsing this forum: Amazon [Bot] and 3 guests
