It is currently Sun Nov 29, 2026 2:05 pm
PostPosted: Tue Nov 20, 2001 4:40 pm
In building my performance 225 my Cam Manufacturer recommends setting the Intake at 18 and Exhaust at 20 (Hot). What should it be set at Cold prior to startup????????? How much variance is normal between cold and hot??????
usclstaffingnet@sprintmail.com
PostPosted: Tue Nov 20, 2001 9:47 pm
: In building my performance 225 my Cam
: Manufacturer recommends setting the Intake
: at 18 and Exhaust at 20 (Hot). What should
: it be set at Cold prior to startup?
: How much variance is normal between cold and
: hot?
I leave mine .002 loose for a first time start-up so .020 & .022 should work for your cam.
