It is currently Tue Oct 13, 2026 4:18 am
 Post subject: water pump differences?
PostPosted: Fri Jul 25, 2008 7:40 pm
Car Model: 1965 Dart 270 w/ 66 Valiant front clip
Did the slant six cars use a different water pump for cars with a/c like the v8 cars did? I know the 318 and 360 cars with air had another blade or two on the backside but am not sure about the /6 cars with ac???
PostPosted: Fri Jul 25, 2008 10:12 pm
I don't think that slant six cars with AC had a different water pump than those without AC, but I'm not positive.
Anybody else?
'78 Volare 225
'67 Charger 318
PostPosted: Sat Jul 26, 2008 6:20 am
Same pump but some A/C cars had more blades or even clutch fans.
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Sat Jul 26, 2008 7:08 am
Most of the factory pumps used a stamped empeller. This looks like a cookie cutter. Fewer in production were pumps that used a cast iron closed empeller. This pump is more efficient and produces less cavitation.
Mitch
PostPosted: Sat Jul 26, 2008 7:43 pm
Cast iron or phenolic-over-cast-iron-hub impeller through '67, stamped steel impeller '68-up. No systematic differences with/without air conditioning or heavy duty cooling. The only real such difference is that in 1960 (only), the 170 used a 3¼" diameter impeller while the 225 used a 3½" impeller. Starting in '61, all pumps used the 3½" impeller. I prefer the cast (iron or phenolic) impeller, too, but the stamped steel ones seem to work fine.
Users browsing this forum: Amazon [Bot], DuckDuckGo [Bot], Google [Bot] and 3 guests
