It is currently Sun Nov 29, 2026 11:02 pm
 Post subject: flywheel adapter
PostPosted: Sun Jul 27, 2008 5:36 pm
Im putting a 1963 sl6 in my 79 dodge van and the flywheel hole is larger then the crank, what do I need, new flywheel or is there some kind of adapter?
1979 dodge sportsmen camper van
PostPosted: Sun Jul 27, 2008 6:30 pm
Hello,
PM me if interested...I have a spare used (not new) but perfect small hub flywheel left over from a truck project. Cheap plus shipping.
rock
'64d100
PostPosted: Mon Jul 28, 2008 4:23 pm
It is better to use the correct flywheel.
 Post subject: Flywheel match Ups
PostPosted: Tue Jul 29, 2008 10:16 am
This applies to my 1967 Plymouth Barracuda Formula S:
I have a similar, but opposite situation for my 273 V8. The Torque converter stub is too large for the flywheel.
This makes it impossible to use a transmission for a different engine, say a 904 from a 318.
Will the flywheel from the SL-6 swap w/ the 273? If so, maybe me & kit
pughta swap. However, I'm guessing that the Sl-6 & V8 flywheels don't swap.
PostPosted: Tue Jul 29, 2008 10:49 am
The V-8 flywheel has one bolt hole with different placement, it about 1/2 of a hole diameter of a difference. Racers have been known to "slot-out" that hole so that V-8 flywheel can be used on a SL6.
As for using a 904 automatic... there is no flywheel, these have a flex plate. There is a difference in torque converter hub / crank counterbore sizes but there is an adaptor bushing made to allow the small coverter nose to fit into the larger crank counter bore.
There are limited (less attractive) options for using later "big hub" (input shaft) converters in the "small c-bore" crank. You can have a special converter made, you can machine-out the back of the crank or you can change-out the input shaft in the transmission.
