It is currently Fri Nov 13, 2026 9:29 pm
PostPosted: Thu Aug 21, 2008 9:51 am
I was just brainstorming and was looking at the area between the valve cover and the manifolds, I'm wondering if it wouldn't be a half decent idea to mill that area smooth and then drill for the injectors to get them nice and close to the backs of the valves?
I have only one slant and it is installed in my car so this is just a little playful "Bench Engineering" but any thoughts would be welcome.
It is easier to REACT,
than it is to THINK!
Middy.
PostPosted: Thu Aug 21, 2008 10:00 am
You would have to bore a big hole and weld/braze/epoxy in a tube as there is water between that ledge above the port face and the intake ports.
PostPosted: Thu Aug 21, 2008 10:10 am
Yep, lots of water jacket there. Not worth the trouble, IMHO.
PostPosted: Thu Aug 21, 2008 10:32 am
Isn't the head also significantly hotter then the intake?
 Post subject: Yep...
PostPosted: Thu Aug 21, 2008 6:02 pm
I would worry also if the mix was run too lean for too long, you might melt the o-rings on the injectors... or worse...
PostPosted: Fri Aug 22, 2008 6:53 am
I should have guessed there was a jacket there, they built the Slant so strong I guess I just figured the head was solid! :) Thanks for the input.
Middy.
PostPosted: Fri Aug 22, 2008 1:16 pm
That Sounds like a option For the Next slant Head that comes along:) or maybe even direct injection!
PostPosted: Fri Aug 22, 2008 3:00 pm
This is something I thought about, too. Even drilled a hole in a junk head to check. It does make for nice injector targeting - right at the valve! But I decided the machining/sealing issues made it not worth the trouble.
O==\=/==O
"A mechanic is Somebody."
- Jim Preston
 Post subject: Old Article
PostPosted: Sat Aug 23, 2008 3:32 am
Years ago (70s), there was an article on a Plymouth Cricket Wagon that had a highly modified slant. They actually cut a bunch of the area of the port out of the way and pressed in tubes. They then placed a cut carb on top of each tube. Needless to say it look really awesome and ran in the tens. I don't remember which mag it was in, but that is what hooked me on the thought of a hot six.
PostPosted: Wed Aug 19, 2009 5:05 am
What is a "cut carb?"
PostPosted: Wed Aug 19, 2009 7:46 pm
They cut the dominator carb right in half. They then placed the half of the carb right over the top of two cylinders.
PostPosted: Fri Sep 18, 2009 5:36 pm
Car Model: 1964 Valiant
Maybe you could mill a hole and install a iron tube with pipe threads, then set the injector in the bottom of the tube, with an o-ring in the bottom?
PostPosted: Sat Sep 19, 2009 9:30 am
Wasn't there somebody already doing this? I thought I saw recent pictures of a head drilled out for the tubes, on this site.
PostPosted: Mon Sep 21, 2009 9:32 am
check the fifth or sixth thread down from top
PostPosted: Mon Sep 21, 2009 4:37 pm
Yep that's the one.
http://slantsix.org/forum/viewtopic.php?t=31675
