It is currently Mon Nov 09, 2026 7:16 pm
PostPosted: Mon Sep 08, 2008 5:27 pm
Was looking at some one wire alts, and one had 3 posts.....one said batt, one was"dummy", and the other was stater.I had no idea what this was refering too......maybe a ignition lead? voltage reg? Besides.......who ever head of a 1 wire w/ 3 wires??Thanks in advance for the help.
Andrew/Kidd
Wife's: 64 Valiant
My: 70 Road Runner, 67 Barracuda, AND the 62 Valiant drag car!!
PostPosted: Mon Sep 08, 2008 6:14 pm
The stator is the fixed winding attached to the alternator case. Most alternators have a rotating field which uses a small current relative to the output. With a fixed field the brushes would have to carry the relatively large output of the armature.
I'm not a big fan of 1-wire alternators. I prefer an alternator with two wires so that the regulator senses the voltage on a wire separate from the alternator's output wire. This allows the voltage regulator to raise the alternator output to compensate for voltage drop between the alternator's output and the load.
