It is currently Sun Nov 15, 2026 8:19 am
 Post subject: Super Six vs 4bbl
PostPosted: Tue Oct 14, 2008 6:16 am
I have an 80 Volare that is bering converted to a 4 speed. It us a 1 bbl and I have acquired a Siper Six setup (one aluminum and one cast iron intake) I am also adding MOPAR performance 6-1 Headers. For now I am leaving the stock cam.
Im wondering if is is worth selling off the 2 Super six setups and going with one of the Aussie performance 4 barrell setups? I have had good luck with Edelbrock carbs in the past but a 500 cfm will be too big, the 390 may be too much for the stock setup even with headers. What do you think?
Scott
Scott
1956 Dodge Custom Royal Lancer
1980 Road Runner (Dont call it a Volare!)
2002 Dodge Ram 1500 Quad Cab
1976 Corvette Stingray
PostPosted: Tue Oct 14, 2008 6:57 am
Scott
For right now I would keep the super 6. If later on you want to take the engine down for mods then I would go 4bbl.
my02
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Tue Oct 14, 2008 8:21 am
The Super 6 is good far beyond what is generally assumed.
My car has a 5 speed , 3.55 gears . 9.6 compression , big valves and an Erson 280 cam. The BBD keeps up until about 4500 rpm and starts to fall off. However the low end torque is a ton better than any too big, bogging 4 barrel .
The driveability of the BBD on a semi hot street car makes it my choice.
