It is currently Sat Aug 15, 2026 7:44 am
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 8 posts ]
 Post subject: Header Paint
PostPosted: Sat Feb 16, 2002 7:25 am
Any recommendations on what kind of Header paint to use on a new set of headers? The last set I installed 15 years ago, I painted black. But shortly after running them they turned white for about 3 or 4" out from the head. Is there any way to keep the paint on and the color it is supposed to be for a reasonable amount of time.Or is that just the nature of the beast/
Thanks for all your help.
Rick
rcovalt@innernet.net
 Post subject: Re: Header Paint *PIC*
PostPosted: Sat Feb 16, 2002 4:55 pm
: Any recommendations on what kind of Header
: paint to use on a new set of headers? The
: last set I installed 15 years ago, I painted
: black. But shortly after running them they
: turned white for about 3 or 4" out from
: the head. Is there any way to keep the paint
: on and the color it is supposed to be for a
: reasonable amount of time.Or is that just
: the nature of the beast/
I am real happy with POR-20 from Restomotive Laboratories. Anyway the attached picture is the headers after 10k miles. I have had to touch up a couple spots right where the tubes turn down from the flange and urder the car where they get road blasted.
Real good Stuff! :-)
dave.clement@motorola.com
PostPosted: Sat Feb 16, 2002 5:13 pm
: I am real happy with POR-20 from Restomotive
: Laboratories. Anyway the attached picture is
: the headers after 10k miles. I have had to
: touch up a couple spots right where the
: tubes turn down from the flange and urder
: the car where they get road blasted.
: Real good Stuff! :-)
Thanks for the info Dave. I could not view the picture, though?
Rick
PostPosted: Sat Feb 16, 2002 8:36 pm
: Thanks for all your help.
: Rick
Just something else to think about,I sent my hedders out and had them coated. The company had lots of colors and they said if the coating came off they would fix them for free. The only bad part it ran around $120.00 to coat them.
damuel@kalama.com
PostPosted: Sun Feb 17, 2002 5:05 am
: Just something else to think about,I sent my
: hedders out and had them coated. The company
: had lots of colors and they said if the
: coating came off they would fix them for
: free. The only bad part it ran around
: $120.00 to coat them.
Dave M.---
Is this a cerametallic coating? If so, that price, though a hefty chunk of change, is alot cheaper than I've seen quoted. Supposedly, those cerametallic coatings significantly reduce the heat radiated by headers...any comment on that? That could be a consideration that would impact longevity of starters and engine block paint (especially with block huggers). What's the outfit's name. website, address and/or phone#? Thanks.
---Red
Torr66@aol.com
PostPosted: Sun Feb 17, 2002 11:54 am
: Dave M.---
: Is this a cerametallic coating? If so, that
: price, though a hefty chunk of change, is
: alot cheaper than I've seen quoted.
: Supposedly, those cerametallic coatings
: significantly reduce the heat radiated by
: headers...any comment on that? That could be
: a consideration that would impact longevity
: of starters and engine block paint
: (especially with block huggers). What's the
: outfit's name. website, address and/or
: phone#? Thanks.
: ---Red
They are located near Portland,Or. When I sent my hedders in they looked pretty sad. I used all new 1 5/8 tubing and Tig welded them all together,but they looked like I just welded them. I also thought about paint and than I met Russ at the Bonneville Salt Flats were he was racing a inline Chev 292. I notice his hedders and they looked great. This is where he talked me into sending him my hedders. After he finished them and where installed I had many people remark on the quality of his workmanship. All I can say he did a great job!
Russ Meeks
R&M Engineering
2889 S.E. Sliver Springs Road
Millwaukie, Oregon 97222
503 659 4278
<A HREF="http://www.finishlinecoatings.com">www.finishlinecoatings.com</A>
damuel@kalama.com
PostPosted: Sun Feb 17, 2002 5:10 pm
Dave M...
Will definitely bookmark the site...could come in handy this spring. I've got relatives up in Portland, so maybe I'll kill 2 birds with 1 stone! Do you remember about what the turnaround time on coating your headers was? Thanks for the tip.
---Red
Torr66@aol.com
PostPosted: Sun Feb 17, 2002 10:26 pm
: Dave M...
: Will definitely bookmark the site...could come
: in handy this spring. I've got relatives up
: in Portland, so maybe I'll kill 2 birds with
: 1 stone! Do you remember about what the
: turnaround time on coating your headers was?
: Thanks for the tip.
: ---Red
I think it took around two weeks. If you call Russ ahead of time I'm sure he could make some kind of arangement if you are on a tight time frame.
damuel@kalama.com
