It is currently Tue May 19, 2026 5:42 pm
PostPosted: Sat Feb 21, 2009 4:41 pm
We are trying to ge my new trans in but everytime we tighten the trans case to the motor, we cant move the converter, or even turn the motor over by hand, its stuck. Loosen it just a bit and everythings fine. Is this normal? Can I just bolt the flex plate to the converter and tighten everything down and be done?
14" Cragar SS wheels
PostPosted: Sat Feb 21, 2009 4:46 pm
Have you made sure the converter is fully seated into the trans?
PostPosted: Sat Feb 21, 2009 5:05 pm
Yes, and I did the test in the FSM that says to put a straight edge on the case and measure from the converter to the straight edge.
PostPosted: Sat Feb 21, 2009 6:48 pm
<'67 crank to '68+ TC?
PostPosted: Sat Feb 21, 2009 8:43 pm
6 Pack Dart
Pull convertor off transmission and see if it will fit the crank (I had a crank that was crushed in on the end and the convertor would not seat in the crank).
 Post subject: trans help
PostPosted: Sun Feb 22, 2009 7:14 am
check all the things other people have posted,there all good suggestions.My guess is the converter slid forward off the splines during install.I made some "fingers" out of 1x 1/8 band stock,these bolt to the bottom splash shield mounting bosses on the bell housing and hold the converter rearward during install
PostPosted: Sun Feb 22, 2009 7:17 am
Well we were able to hold the converter back, and are now able to move it somewhat by hand. The motor turns over with the starter, so I think were going to try and start it.
PostPosted: Sun Feb 22, 2009 10:41 am
The hub on the new TC is too big, and to add to that, the flex plate is bent. Im just going to just use the old TC, and an extra flex plate we have.
 Post subject: trans
PostPosted: Sun Feb 22, 2009 11:14 am
Id start taking lots of pictures,the trans is probably ruined.Measure the TC snout Dia. and the crank pilot ID.And let us know what they are. If you have a pre 68 engine or crank in your car,then it,s not the trans shop,s fault.If they sent the wrong converter then it is. I once bought a rebuilt 727 converter that had pre 66 coarse splines in it.
PostPosted: Sun Feb 22, 2009 11:22 am
If you have a small pilot crank you can't just use the old converter; the splines in the front of the tranny are wrong and it won't mate up properly.
David Kight
'62 Valiant Signet, White
'98 Dodge Dakota
'06 Jeep Liberty
 Post subject: Re: trans
PostPosted: Sun Feb 22, 2009 2:50 pm
The two "teeth" on the pump are broken. My engine im guessing is post 68 because it has 5 freeze plugs, not 3. The trans Im trying to put in is a '70. I will get out and measure here soon.
Wasn't there some difference between the 198 and the 225?
 Post subject: trans
PostPosted: Sun Feb 22, 2009 5:37 pm
The teeth broken off the oil pump means the trans needs repaired,might have extensive damage inside.The most common cause is the TC slidding foward and getting misalgined.But you need to find out if the TC was defective or if it,s the wrong crank pilot.
PostPosted: Mon Feb 23, 2009 2:15 pm
Whats the difference between the 60-67 trans and the the 68+ trans? Im starting to wonder if I have an earlier crank, whats the measurements of the crank pilot?
PostPosted: Mon Feb 23, 2009 2:27 pm
6 Pack Dart
Early about 1.555", newer 1.812"
PostPosted: Fri Feb 27, 2009 2:24 pm
Is there any difference between the automatic trans and manual trans
cranks?
