It is currently Sun May 24, 2026 7:41 am
PostPosted: Mon May 04, 2009 1:30 pm
I can find a label through the muck, was there 1 or 2 standard gear ratios in the smaller rears on the '70 'A" bodies?
1970 Valiant.. my sons Daily Driver
1975 CJ5, fiberglass body,350/345Hp chevy
1985 chevy stepside pickup, Original Owner
1989 Volvo 240: Original Owner
OTHER TOYS: http://home.no.net/ebrox/Tony's%20cars.htm
PostPosted: Mon May 04, 2009 3:05 pm
Most automatic trans cars used the 2.76 or a 2.93 geaar ratio in the 7 1/4 rearend.
PostPosted: Tue May 05, 2009 6:07 am
PostPosted: Tue May 05, 2009 9:23 am
Yup, if yours is an original rear axle and no special ratio was specified when the car was ordered, it's 2.76, which became the standard ratio with automatic transmission starting in '68 or '69. But over this many years who knows how many rear axles might've been swapped in. You might want to check the actual ratio. See this thread.
PostPosted: Tue May 05, 2009 10:18 am
I know I could have counted the Pinion and axle ... I just went through this with my other sons Jeep. That CJ was more than tinkered with.. nothing was 'right'
I was just hoping someone would pipe on as you did with the Standard for the time.
